On Oct 6, 12:14 am, Le Chaud Lapin wrote:
On Oct 5, 6:32 pm, wrote: People are going to yell and boo me for saying this, but after taking a nice long ride tonight on my motorcyle tonight, I thought the venturi/Bernoulli thing through, and I am 95% certain that that is not the reason the pressure is lower. In fact, I could probably provide an experiment showing you a situation where air is moving considerably faster on top than it is on the bottom, with much higher presure on the top. What is ironic is that Bernoulli would still be right, but the interpretation of Bernoulli would fall apart. You keep talking about designing this experiment. Nothing was ever accomplished with a lot of empty talk. When are you going to start proving your theories? If you come up with something truly revolutionary, we will all bow and scrape and tell our friends that we had mistakenly defied a true master. Newton said that for every action there's an equal and opposite reaction. If you look at the diagrams of airflow here,http://www.av8n.com/how/htm/airfoils.html scrolling down to Figure 3.2, you'll see that there's upwash ahead of the wing as well as downwash behind it. the upwash is generated by the approaching low pressure area above the wing. As the wing passes, the upwash is converted to downwash; if this isn't Newton at work, I don't know what is. Newton would be just another dead guy. Newton did say that. And I looked at that diagram very carefully. [Thanks for link] The upwash is not casued by an approaching low pressure. The upwash is caused by a gradient in pressure, going from high pressure at the leading ede, to low pressure, right above and slightly-back of the wing, due to rarefication of the wing in motion. And that's not an effect of the approaching low pressure? In any subsonic flow, the effect of any disturbance of the air travels outward at the speed of sound. An approaching wing will affect air molecule movement well ahead of it. The area above the rarefication is normal atmosphere that has a propensity to move toward the lower-pressure, rarefied air. The combination of that normal atmosphere air, combine with the high velocity of the molecules from the leading edge of the wing, results in the flow paths (streams) that you see. I haven't looked yet, but I imagine that there are aerodynamicists, all over the world, who, if not for appreciation of the hypothesis I am proposing here, have at least figured this out empircally, and are fretting day and night trying to find the optimal shape of the leading edge of the wing. They have two conflicting objectives: 1. Make the shape in such a way so as to minimize drag. 2. Make the shape in such a way so as to increase pressure to impart high velocity to air molecules moving up/backwards. I'll be the first to admit that i don't have the capacity to do so at this moment, but imagine that that one shape of the leading edge is not appropriate for all speeds of the aircraft. Finally, two true statements: 1. You don't have the capacity, and 2. The leading edge you see is not appropriate for all speeds of aircraft. There are MANY different leading edges out there. I imagine you haven't seen them. For a given set of context variables like density, temperature, pressure, angle-of- attack, airspeed, what-the-plane-was-doing-20-milliseconds-ago, turbulences...wind, etc...there is an optimal shape for that leading edge, depending on what you are trying to do. It would be quite wild if someone were to design a wing that could morph, dynamically by control of a computer, into an instaneously-optimal shape. As if the engineers haven't been working on these wings for years already. I have an article on my desk in front of me about morphing helicopter blades to deal with retreating-blade stall. You didn't really think you had a new idea, did you? We already have variable-geometry wings. The fighter's swing- wings, the airliner's triple-slotted flaps and its leading-edge slats and flaps, on and on. All varying the airfoil for different speed regimes and maneuvers. The problem with your instantaneous change is one of maintaining structural integrity and strength and resistant to flutter while keeping the weight low enough that it will fly. Maybe you can solve that for us. I believe it should be possible to explain a venturi tube, Bernoulli's principle, and a decent part of why a wing has lift, in about 2-3 pages of written text, with pictures, using no formulas, not even grade-school mathematics. Commonly done in many texts. You just haven't read them yet. If a student wants to argue that the physics as presented are all wrong he should do extensive research and publish a book on the subject, not argue with pilots who have been trusting their soft pink bodies to Bernoulli and Newton for decades. I definitely agree a paper should be written, and there should be an element of rigor, obviously lacking in my posts. ![]() Obviously. There is a flow of goofy ideas through your head, increasing in velocity, so that a vacuum is forming there. Dan |
On Oct 6, 2:09 pm, wrote:
I believe it should be possible to explain a venturi tube, Bernoulli's principle, and a decent part of why a wing has lift, in about 2-3 pages of written text, with pictures, using no formulas, not even grade-school mathematics. Commonly done in many texts. You just haven't read them yet. Which texts are those? I have read some texts: 1. Jeppesen got it wrong. 2. Rod Machado got it wrong. 3. That link that with the funny color lines that was posted in this thread got it wrong. 4. If you do search in Google for "Bernoulli" + "faster" + wing + lift, you will see 1000's of pages that got it wrong. Plus I watched 3 CFI's at my ground school, the one I paid money to teach me the theory of flying, get it wrong at the whiteboard. And of course, if the NASA paper is true, then there are even people in this group who got it wrong. Until 3 days ago, the number of people who had gotten (partially) right was 1. The number of stories I had heard from people who got it wrong was probably about 60-70. After reading the link that Jim Logajan posted, the number of people who are saying it's one way is 2. The number of people who are saying it is the exact opposite is still 60-70. Which textbooks would you believe if you had read 1 saying one thing, and more than 10 others saying the exact opposite? -Le Chaud Lapin- |
Le Chaud Lapin wrote in
ps.com: On Oct 6, 2:09 pm, wrote: I believe it should be possible to explain a venturi tube, Bernoulli's principle, and a decent part of why a wing has lift, in about 2-3 pages of written text, with pictures, using no formulas, not even grade-school mathematics. Commonly done in many texts. You just haven't read them yet. Which texts are those? I have read some texts: 1. Jeppesen got it wrong. No they didn't 2. Rod Machado got it wrong. Don't know who he is but if you thnk he's wrong he can't be. 3. That link that with the funny color lines that was posted in this thread got it wrong. Nope. 4. If you do search in Google for "Bernoulli" + "faster" + wing + lift, you will see 1000's of pages that got it wrong. Nope. Plus I watched 3 CFI's at my ground school, the one I paid money to teach me the theory of flying, get it wrong at the whiteboard. There's too many things wrong with this sentence to even start on. And of course, if the NASA paper is true, then there are even people in this group who got it wrong. Well, you did , as botht yourself and your sockpuppet. Until 3 days ago, the number of people who had gotten (partially) right was 1. Oha, and who was that? Bertie |
On Oct 6, 1:32 pm, Le Chaud Lapin wrote:
On Oct 6, 2:09 pm, wrote: I believe it should be possible to explain a venturi tube, Bernoulli's principle, and a decent part of why a wing has lift, in about 2-3 pages of written text, with pictures, using no formulas, not even grade-school mathematics. Commonly done in many texts. You just haven't read them yet. Which texts are those? I have read some texts: 1. Jeppesen got it wrong. 2. Rod Machado got it wrong. 3. That link that with the funny color lines that was posted in this thread got it wrong. 4. If you do search in Google for "Bernoulli" + "faster" + wing + lift, you will see 1000's of pages that got it wrong. All wrong, according to you. There's no point pointing out any others. They'll be wrong, too. Plus I watched 3 CFI's at my ground school, the one I paid money to teach me the theory of flying, get it wrong at the whiteboard. Rather common, distressingly. However, he may have had it right; you have just determined that EVERYONE but you is wrong. And of course, if the NASA paper is true, then there are even people in this group who got it wrong. Until 3 days ago, the number of people who had gotten (partially) right was 1. The number of stories I had heard from people who got it wrong was probably about 60-70. After reading the link that Jim Logajan posted, the number of people who are saying it's one way is 2. The number of people who are saying it is the exact opposite is still 60-70. Which textbooks would you believe if you had read 1 saying one thing, and more than 10 others saying the exact opposite? Does truth in physics depend on a democratic vote? Dan |
On Oct 6, 2:51 pm, wrote:
On Oct 6, 1:32 pm, Le Chaud Lapin wrote: I have read some texts: 1. Jeppesen got it wrong. 2. Rod Machado got it wrong. 3. That link that with the funny color lines that was posted in this thread got it wrong. 4. If you do search in Google for "Bernoulli" + "faster" + wing + lift, you will see 1000's of pages that got it wrong. All wrong, according to you. There's no point pointing out any others. They'll be wrong, too. Plus I watched 3 CFI's at my ground school, the one I paid money to teach me the theory of flying, get it wrong at the whiteboard. Rather common, distressingly. However, he may have had it right; you have just determined that EVERYONE but you is wrong. It wasn't just one. It was 3. My instructor, plus 2 others. They said the thing that the NASA paper is calling "a myth". Who is right? The NASA author or the CFI's? And of course, if the NASA paper is true, then there are even people in this group who got it wrong. Until 3 days ago, the number of people who had gotten (partially) right was 1. The number of stories I had heard from people who got it wrong was probably about 60-70. After reading the link that Jim Logajan posted, the number of people who are saying it's one way is 2. The number of people who are saying it is the exact opposite is still 60-70. Which textbooks would you believe if you had read 1 saying one thing, and more than 10 others saying the exact opposite? Does truth in physics depend on a democratic vote? That's what I am asking... After reading 60-70 that says one thing, and seeing 2 others that says the exact opposite, and it just happen to be that the 2 are the ones that you personally agree with, which would you believe? The 60-70? The 2? Flip a coin? -Le Chaud Lapin- |
ups.com: On Oct 6, 2:51 pm, wrote: On Oct 6, 1:32 pm, Le Chaud Lapin wrote: I have read some texts: 1. Jeppesen got it wrong. 2. Rod Machado got it wrong. 3. That link that with the funny color lines that was posted in this thread got it wrong. 4. If you do search in Google for "Bernoulli" + "faster" + wing + lift, you will see 1000's of pages that got it wrong. All wrong, according to you. There's no point pointing out any others. They'll be wrong, too. Plus I watched 3 CFI's at my ground school, the one I paid money to teach me the theory of flying, get it wrong at the whiteboard. Rather common, distressingly. However, he may have had it right; you have just determined that EVERYONE but you is wrong. It wasn't just one. It was 3. My instructor, plus 2 others. They said the thing that the NASA paper is calling "a myth". Who is right? The NASA author or the CFI's? And of course, if the NASA paper is true, then there are even people in this group who got it wrong. Until 3 days ago, the number of people who had gotten (partially) right was 1. The number of stories I had heard from people who got it wrong was probably about 60-70. After reading the link that Jim Logajan posted, the number of people who are saying it's one way is 2. The number of people who are saying it is the exact opposite is still 60-70. Which textbooks would you believe if you had read 1 saying one thing, and more than 10 others saying the exact opposite? Does truth in physics depend on a democratic vote? That's what I am asking... After reading 60-70 that says one thing, and seeing 2 others that says the exact opposite, and it just happen to be that the 2 are the ones that you personally agree with, which would you believe? The 60-70? The 2? Flip a coin? You don't fly and you never wil, therefore it doesn't matter. Bertie |
On Oct 6, 2:09 pm, wrote: I believe it should be possible to explain a venturi tube, Bernoulli's principle, and a decent part of why a wing has lift, in about 2-3 pages of written text, with pictures, using no formulas, not even grade-school mathematics. Commonly done in many texts. You just haven't read them yet. Which texts are those? I have read some texts: 1. Jeppesen got it wrong. 2. Rod Machado got it wrong. 3. That link that with the funny color lines that was posted in this thread got it wrong. 4. If you do search in Google for "Bernoulli" + "faster" + wing + lift, you will see 1000's of pages that got it wrong. I just added you to my kill file so I don't have to read your drivel any longer so I'd say I'm the only one so far to get it right! :-) |
How much lift do you need? | Dan Luke | Piloting | 3 | April 16th 07 02:46 PM |
Theories of lift | Avril Poisson | General Aviation | 3 | April 28th 06 07:20 AM |
what the heck is lift? | buttman | Piloting | 72 | September 16th 05 11:50 PM |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
thermal lift | ekantian | Soaring | 0 | October 5th 04 02:55 PM |
