Backwash Causes Lift?
Old October 8th 07, 05:46 PM posted to rec.aviation.piloting
Mxsmanic
Default Backwash Causes Lift?
Le Chaud Lapin writes:
"the molecules stay in contact with the solid body"...?????????????
Why?
Supposedly this is the Coanda effect at work, but there remains considerable
debate about this.
  #272
Old October 8th 07, 05:47 PM posted to rec.aviation.piloting
Mxsmanic
Bertie the Bunyip writes:
Yes, they can, and do.
Which ones? How do you accelerate an aircraft without accelerating anything
downward?
  #273
Old October 8th 07, 05:54 PM posted to rec.aviation.piloting
Morgans[_2_]
"Jim Logajan" wrote
Grumble. Now I recall why I had established a personal policy to stay away
from discussions of aerodynamics on this newsgroup: futility avoidance.
No, you need to stay away from discussions with MX, or Le chad, or
flightoffancy, who are all one and the same.
ANY discussion with them is an exercise in futility.
Just say no.
Jim in NC
  #274
Old October 8th 07, 06:24 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Why?
considerable debate about this.
Only amongst k00ks.
bertie
  #275
Old October 8th 07, 06:25 PM posted to rec.aviation.piloting
Default OK, IF Backwash Causes Lift then...
Bertie the Bunyip wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in
How does a gyrocopter fly because the airflow over it's "wing" is
going up.
They're gliders. The same rules apply.
Bertie
I agree the same rules apply, but they aren't gliders unless the
engine craps out.
Jim Pennino
Remove .spam.sux to reply.
  #276
Mxsmanic wrote in
anything downward?
Send me 1,000 bucks and I'll tell you. Otherwise go find out yourself
fruitcake.
Bertie
  #278
Old October 8th 07, 06:32 PM posted to rec.aviation.piloting
Phil
Why?
debate about this.
There isn't any debate about what a wing stall is, and what causes
it. It has been well-explored in wind tunnel testing. The phenomenon
of wing stall is real-world evidence that the top surface of the wing
is a large contributor to lift. The Bernoulli effect and the
associated Coanda effect are well-understood scientific phenomena.
They explain how the curved top surface of the wing displaces air
downward. Unless someone can come up with a better explanation for
the fact that wing stall destroys lift, I think the only debate is by
people who are determined to ignore the scientific evidence.
Phil
  #279
Old October 8th 07, 06:35 PM posted to rec.aviation.piloting
downward?
Acceleration is the second derivative of position.
If the vertical postion of an aircraft is constant, i.e. straight and
level flight, the first derivative of the vertical position is zero and
hence the second derivative is also zero.
Acceleration is the first derivative of velocity.
If the horizontal velocity of an aircraft is constant, i.e. straight and
level flight, the deriviative of the velocity is zero.
An aircraft in straight and level flight is not accelerated.
Jim Pennino
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
