Backwash Causes Lift?
Old October 8th 07, 08:45 PM posted to rec.aviation.piloting
Le Chaud Lapin
Default Backwash Causes Lift?
On Oct 8, 12:32 pm, Phil wrote:
There isn't any debate about what a wing stall is, and what causes
it. It has been well-explored in wind tunnel testing. The phenomenon
of wing stall is real-world evidence that the top surface of the wing
is a large contributor to lift. The Bernoulli effect and the
associated Coanda effect are well-understood scientific phenomena.
They explain how the curved top surface of the wing displaces air
downward. Unless someone can come up with a better explanation for
the fact that wing stall destroys lift, I think the only debate is by
people who are determined to ignore the scientific evidence.
What's wrong with the supposition that, all other things being equal,
the configuration of the fluid in a smooth stream results in less
pressure on the upper surface than the configuration of the fluid in
turbulence?
In other words, one could argue that the fluid above the wing, during
streaming (sorry for terminology), no longer exerts its full 14.7lbs/
in^2, but during a stall, even though there is still is some reduction
from the full 14.7lbs/in^2, the reduction is not as complete as it
would have been had there been a nice stream...
-Le Chaud Lapin-
Old October 8th 07, 08:49 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Le Chaud Lapin wrote in
oups.com:
phenomenon
phenomenon
turbulence?
God you're even dummer as a sockpuppet
bertie
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
