pushrod tube leak
Old October 9th 07, 07:07 PM posted to rec.aviation.owning
Tri-Pacer
Default pushrod tube leak
Was thinking something like replacing an axle boot on a front wheel drive
car with those split and bolted types...
It would be helpful to know the type of engine, some engines (Cont) have
the pushrod tube swedged into the head.
I think Real Gasket makes a kit to replace the Continental pushrod tubes
with removable tubes. If you do pull a small Continental cylinder to replace
the pushrod seal then there's that AD to dye check the rocker arm bosses for
cracks--------
Cheers:
Paul
N1431A
KPLU
C85 Oil Leak Dick[_1_] Owning 2 May 2nd 07 11:00 PM
Oil leak spotted around push rod tube seals Peter R. Owning 9 February 13th 05 04:10 PM
Oil leak Gene Seibel Owning 10 January 4th 05 02:57 PM
oil leak question Dick Home Built 18 November 19th 04 03:14 PM
Oil leak mike regish Piloting 9 June 22nd 04 03:46 AM
