Le Chaud Lapin wrote in
oups.com: On Oct 9, 1:00 pm, Phil wrote: I think you mis-understood me here. When I say the air below the line is pressing upward, I am not referring to the air pressing upward on the bottom of the wing. I am referring to the air _inside_ the wing pressing upward on the underside of the top surface of the wing. The air above the wing top surface has lower than normal pressure. The air inside the wing has normal pressure. So it presses upward on the top surface of the wing. This is lift generated by the top surface of the wing. Air _inside_ the wing. Hmm...please don't take this the wrong way, I can assure I don't mean it as an insult, but what do you do for a living and what is your technical bacground (math, physics, etc.) if you don't mind my asking? If air inside the wing pushes upward on the underside of the top of the wing, it also pushes downward on the overside of the bottom of the wing, thus nullifying any effect of the air inside the wing. Wow, you're like, the next einstien, dude. Bertie |
How much lift do you need? | Dan Luke | Piloting | 3 | April 16th 07 02:46 PM |
Theories of lift | Avril Poisson | General Aviation | 3 | April 28th 06 07:20 AM |
what the heck is lift? | buttman | Piloting | 72 | September 16th 05 11:50 PM |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
thermal lift | ekantian | Soaring | 0 | October 5th 04 02:55 PM |
