How come the wings bank when I use the rudder
Old October 22nd 07, 01:52 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default How come the wings bank when I use the rudder
Bertie the Bunyip wrote:
Dudley Henriques wrote in news:1dCdnWn-
OK, I think I have it. There're (roughly) similar problems with the
transonic stuff I fly but for some different reasons. Surely there are
some buffet isssues with the ailerons at large displacements as well?
Bertie
I've not noticed aileron buffet in the 38 even at max deflection. The
ailerons are extremely effective on the airplane.
About buffet; you actually work high performance jets like the 38 by
using the buffet boundary. You can pull the pole and feel the buffet
onset in pitch. It's a highly effective warning when maneuvering hard.
you're talking mach buffet now, right? not normal flow seperation..
I would have thought you might get buffet problems with large deflections
in and around transonic flight. We can, certainly, but our airplanes aren't
desingned for supersonic flight, of course..
bertie
The buffet limit is actually the subsonic buffet limit and defines the
lift limit line for the 38. In other words, below corner speed, you are
aerodynamically limited in maneuvering room by the lift limit line which
basically means you can pull to the buffet.
In effect, the tactical buffet line defines the left side of the T38's
flight envelope.
Dudley Henriques
Old October 22nd 07, 02:08 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
news
are some buffet isssues with the ailerons at large displacements as
well?
Bertie
The ailerons are extremely effective on the airplane.
hard.
deflections in and around transonic flight. We can, certainly, but
our airplanes aren't desingned for supersonic flight, of course..
bertie
are aerodynamically limited in maneuvering room by the lift limit line
which basically means you can pull to the buffet.
flight envelope.
Yeh, OK I understand buffet in relation to loading but the control
deflections have no effect on the onset of buffet? Is that not why you
have a limit when close to mach 1?
Bertie
Old October 22nd 07, 02:27 PM posted to rec.aviation.piloting
news
well?
Bertie
hard.
bertie
flight envelope.
Bertie
The roll restriction is totally unrelated to tac buffet. For all
practical purposes you can forget aileron buffet as a problem in the
T38. The issue with the roll limit is divergence through inertia roll
coupling. In other words, at the q found at .9 Mach and above, max
aileron throw will generate a roll rate high enough that the roll axis
changes from pure roll and couples either in pitch or with yaw or even
both under specific angles of attack as the roll is initiated; and this
NEW roll axis is so unstable due to the IYMP that departure is a real
possibility.
Dudley Henriques
Old October 22nd 07, 02:33 PM posted to rec.aviation.piloting
news
there
as
well?
Bertie
by
buffet
hard.
bertie
line
T38's
flight envelope.
you
Bertie
this
possibility.
OK, which is what you posted originally before I went off on a tangent!
I suppose I was thinking that the divergence was started off by a mach
buffet triggered by the ailerons, but I'm with you now. I think..
Bertie
Old October 22nd 07, 02:39 PM posted to rec.aviation.piloting
news
there
as
well?
Bertie
by
buffet
hard.
bertie
line
T38's
flight envelope.
you
Bertie
this
possibility.
Bertie
We'll have you checked out in the 38 in no time :-))
Dudley Henriques
Old October 22nd 07, 02:54 PM posted to rec.aviation.piloting
news
there
displacements
as
well?
Bertie
deflection. The ailerons are extremely effective on the
airplane. About buffet; you actually work high performance jets
like the 38
by
buffet
hard.
seperation..
but our airplanes aren't desingned for supersonic flight, of
course..
bertie
you are aerodynamically limited in maneuvering room by the lift
limit
line
T38's
flight envelope.
you
Bertie
roll coupling. In other words, at the q found at .9 Mach and above,
max aileron throw will generate a roll rate high enough that the
roll axis changes from pure roll and couples either in pitch or with
yaw or even both under specific angles of attack as the roll is
initiated; and
this
real possibility.
tangent! I suppose I was thinking that the divergence was started off
by a mach buffet triggered by the ailerons, but I'm with you now. I
think..
Bertie
Heh he, 'Who'd pay for the gas?
Bertie
GPS instead of turn and bank Danny Deger Piloting 52 February 8th 07 02:03 PM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
Bank Check Aviation Ron R Piloting 68 January 19th 05 01:30 AM
BREAKING THE BANK Cribsheet Piloting 0 December 22nd 04 06:27 PM
key bank CSA722 Piloting 0 July 14th 03 07:04 AM
