AVGAS 80 & MOGAS
Old October 30th 07, 09:04 PM posted to rec.aviation.piloting
Morgans[_2_]
Default AVGAS 80 & MOGAS
"RST Engineering" wrote
But, as I said, you have to take a full tanker load of it and most
airports can't afford to do that.
Are they allowed to have two or three airports share a full load?
Jim in NC
Old October 30th 07, 10:50 PM posted to rec.aviation.piloting
RST Engineering
Dunno.
"If you think you can, or think you can't, you're right."
--Henry Ford
"Morgans" wrote in message
Jim in NC
Old October 31st 07, 05:11 PM posted to rec.aviation.piloting
Big John
Most tankers have multiple tanks. For example a 8000 gallon tank truck
could have four 2000 gallon tanks. This lets them deliver smaller
amounts of gas to the small Stop & Go type stores that don't want to
invest the dollars in a full load all at one time.
The multiple tanker layout is also a safety feature so that if one
tank starts a leak only part of the load will get out (small possible
fire and clean up and less money lost). Also it lets the tanker carry
different grades of gas (reg, super, extra $ super) on one delivery to
a station.
So, I see no problem (from experience a number of years ago in the gas
business) of dropping less than the full tanker at different
locations.
Only thing might be cost of tanker charge for the extra distance and
time needed to hit several locations??? Also it assumes that several
airports all needed gas at same time so one tanker could hit them all
with the total load of 8000 gallons.
Have a nice day in the land of F's & N's. Only spent 7 wonderful years
flying out there before SF went to the 'F's' )
Big John
On Tue, 30 Oct 2007 15:50:50 -0700, "RST Engineering"
Dunno.
Old October 31st 07, 09:42 PM posted to rec.aviation.piloting
Morgans[_2_]
a station.
Also, it is VERY important to have dividers in a large tanker, so when you
are putzing about with a third of a load, that you don't have the whole load
shift to the front at one time, or back, or whatever.
Jim in NC
Old November 1st 07, 01:24 PM posted to rec.aviation.piloting
Ron Natalie
The tanks will have baffles in ADDITION to the tank segregation. Even
2000 gallons is more than you want to slosh around uncontrolled.
Old November 1st 07, 04:27 PM posted to rec.aviation.piloting
Morgans[_2_]
m...
you are putzing about with a third of a load, that you don't have the
whole load shift to the front at one time, or back, or whatever.
Of course. Baffles will still let all of the liquid flow to one part of the
tank, or the other. It does let it flow much more slowly, and predictably,
so it is not as much of a problem, though.
Jim in NC
"Over time, Mogas deteriorates faster than Avgas" Jay Honeck Piloting 32 September 18th 07 07:41 PM
Mogas for an O-320 with 160 HP? jls Home Built 3 December 31st 04 07:48 PM
Water/Avgas/Gasahol/Mogas Corky Scott Home Built 12 August 17th 04 04:25 AM
Water/Avgas/Gasahol/Mogas jc Owning 11 August 17th 04 04:25 AM
Water/Avgas/Gasahol/Mogas Corky Scott Owning 0 August 11th 04 01:27 PM
