When to descend II
Old October 30th 07, 07:52 PM posted to rec.aviation.ifr
Newps
Default When to descend II
Bee wrote:
If you were on vectors to the ILS, the final heading for intercept
couldn't be greater than 330 coming from that direction.
Heading is not the limiting factor. Track is what the controller is
concerned with. If I could only give you a 30 degree intercept some
days you would never join.
Old October 30th 07, 07:55 PM posted to rec.aviation.ifr
Ron Rosenfeld
On Tue, 30 Oct 2007 18:32:46 -0000, John Godwin
Ron Rosenfeld wrote in
You can certainly navigate TO ROYCE without being established on
the localizer, however.
Vectored, maybe but not navigating.
Why not navigating?
Even without a GPS, you should be able to navigate from 4mi SW of ROYCE to
ROYCE using VOR/LOC and DME (and situational awareness).
With a GPS, there is no problem.
Without a GPS, what you will lack is positive course guidance. But I don't
see where, in the definition of "navigation", that PCG is required.
Old October 30th 07, 10:29 PM posted to rec.aviation.ifr
Bee[_2_]
Ron Rosenfeld wrote:
But he wrote that he had been cleared for the visual.
It was cross ROYCE at or above 2,000, *then* cleared for the visual.
Old October 30th 07, 10:30 PM posted to rec.aviation.ifr
Bee[_2_]
Newps wrote:
You're doing to the visual approach, it's irrelevant what fix I send you
too. It could be a charted one or one I simply made up out of thin air.
Okay, I get it. The IAP is not even in the plan. IFR to a fix, then
visual or, if unable, a new plan. Maybe, the at or above 2,000 at ROYCE
was to keep the pilot at MVA instead of for traffic? You think maybe so?
Old October 30th 07, 10:32 PM posted to rec.aviation.ifr
Bee[_2_]
Oh, yes, I have seen that effect a few times.
Old October 30th 07, 10:37 PM posted to rec.aviation.ifr
No, I meant SW. I was on a vector to join, and then called the field in
sight.
But if you were being vectored for the ILS, on the last vector to join
the localizer, then you were most likely on a 100 degree heading give
or take some wind, on a track to hit the localizer some 3 miles before
ROYCE. So I still doubt that you could have been SW of ROYCE.
My take on it is that since the controller had already planned on
clearing you for the ILS, or perhaps had already done so, your late
request for a visual didn't really change anything and so he intended
for you to continue on your heading to intercept the localizer, fly to
ROYCE and then descend to the runway.
This seems simple unless you left still more out of the story.
Old October 30th 07, 11:53 PM posted to rec.aviation.ifr
Ron Rosenfeld
I don't understand your point.
The approach clearance is frequently/usually/always given after a
fix/crossing restriction.
He was NOT on vectors for an ILS approach.
I do not believe that to proceed direct ROYCE, from 4 miles SW of ROYCE,
for an ILS approach would even meet the requirements for proper ATC
handling.
So he was cleared via ROYCE as part of setting him up for a Visual
Approach.
My guess is that the altitude restriction and course specification was
traffic related. Perhaps there was conflicting traffic for the parallel
runway.
  #28
Old October 31st 07, 01:23 AM posted to rec.aviation.ifr
Bee[_2_]
Because you said:
"But he wrote that he had been cleared for the visual."
handling.
Approach.
Apparently so. Nonetheless, the visual approach was not authorized
until *after* crossing ROYCE at or above 2,000.
runway.
Or, it could have been to assure MVA until ROYCE.
  #29
Old October 31st 07, 01:16 PM posted to rec.aviation.ifr
Dan Luke[_2_]
"Bee" wrote:
Maybe, the at or above 2,000 at ROYCE was to keep the pilot at MVA instead
I think it most likely was for sequencing or traffic. Hobby has a lot
helicopters and other GA of all sizes mixing with SW Airlines 737s.
Dan
T-182T at BFM
  #30
Old October 31st 07, 01:23 PM posted to rec.aviation.ifr
Dan Luke[_2_]
I think that's close to right, but I think he had another reason for the
routing, probably traffic. There are an awful lot of helicopters at Hobby.
The vector I was on was a "right base" for the ILS, not the intercept vector.
I didn't request the visual, just called the field in sight; perhaps that's
splitting hairs.
Dan
T-182T at BFM
When to descend Dan Luke[_2_] Instrument Flight Rules 44 October 14th 07 09:12 AM
