On Nov 2, 7:12 pm, Tina wrote:
OK, so the center of gravity (except for some airplanes with really smart computers) is going to be forward of the center of lift for stall recovery reasons -- that makes sense. The question I have is, for a typical GA flying machine -- take a complex single for example -- what really is the download (I'm thinking of it as induced weight with fuel burn consequences) supplied by the vertical stabilizer? It has a reasonable moment arm hanging way back there, but is it as much as say 100 pounds if the CG is near the forward limit? This isn't an aeronautical problem, its a basic mechanics problem. The moment of the CG vs. the center of lift must equal the moment of the tail plane. If the airplane gross weight is 2500 lbs, and the CG is 1 foot in front of the center of lift, that is a moment of 2500 foot-lbs. If the tail plane is 10 feet behind the center of lift, the force on the stabilizer is 250 lbs. Dean |
oups.com... On Nov 2, 7:12 pm, Tina wrote: OK, so the center of gravity (except for some airplanes with really smart computers) is going to be forward of the center of lift for stall recovery reasons -- that makes sense. The question I have is, for a typical GA flying machine -- take a complex single for example -- what really is the download (I'm thinking of it as induced weight with fuel burn consequences) supplied by the vertical stabilizer? It has a reasonable moment arm hanging way back there, but is it as much as say 100 pounds if the CG is near the forward limit? This isn't an aeronautical problem, its a basic mechanics problem. The moment of the CG vs. the center of lift must equal the moment of the tail plane. If the airplane gross weight is 2500 lbs, and the CG is 1 foot in front of the center of lift, that is a moment of 2500 foot-lbs. If the tail plane is 10 feet behind the center of lift, the force on the stabilizer is 250 lbs. Dean Now for fuel burn increases, factor in the induced drag created by the deflected elevator to create the required down force. Glider pilots attempt to maintain a CG at 75-85% MAC (some will go farther aft), to keep the deflection to create the required down force to a minimum to create the least amount of drag at cruising speed. BT |
"BT" wrote in :
wrote in message oups.com... On Nov 2, 7:12 pm, Tina wrote: OK, so the center of gravity (except for some airplanes with really smart computers) is going to be forward of the center of lift for stall recovery reasons -- that makes sense. The question I have is, for a typical GA flying machine -- take a complex single for example -- what really is the download (I'm thinking of it as induced weight with fuel burn consequences) supplied by the vertical stabilizer? It has a reasonable moment arm hanging way back there, but is it as much as say 100 pounds if the CG is near the forward limit? This isn't an aeronautical problem, its a basic mechanics problem. The moment of the CG vs. the center of lift must equal the moment of the tail plane. If the airplane gross weight is 2500 lbs, and the CG is 1 foot in front of the center of lift, that is a moment of 2500 foot-lbs. If the tail plane is 10 feet behind the center of lift, the force on the stabilizer is 250 lbs. Dean Now for fuel burn increases, factor in the induced drag created by the deflected elevator to create the required down force. Glider pilots attempt to maintain a CG at 75-85% MAC (some will go farther aft), to keep the deflection to create the required down force to a minimum to create the least amount of drag at cruising speed. huh? 75 to 85% MAC? I began to build one years ago and it's CG was in the "usual position" about 25% to 30%, depending on how much you had for lunch I can't see any of the competition gliders being able for a CG in that position either. not with the stab area that they have. A model glider with a massive stab, yes, but not any full size as far as I can see. Anything with a CG that far aft on the main plane is leaning more towards being a tandem wing aircraft than a conventional one. Can you provide an example of one of these? Bertie Bertie |
Bertie... perhaps I miss spoke..
correct.. not 85% MAC... but 85% towards the AFT CG limit.. BT "Bertie the Bunyip" wrote in message .. . "BT" wrote in : wrote in message oups.com... On Nov 2, 7:12 pm, Tina wrote: OK, so the center of gravity (except for some airplanes with really smart computers) is going to be forward of the center of lift for stall recovery reasons -- that makes sense. The question I have is, for a typical GA flying machine -- take a complex single for example -- what really is the download (I'm thinking of it as induced weight with fuel burn consequences) supplied by the vertical stabilizer? It has a reasonable moment arm hanging way back there, but is it as much as say 100 pounds if the CG is near the forward limit? This isn't an aeronautical problem, its a basic mechanics problem. The moment of the CG vs. the center of lift must equal the moment of the tail plane. If the airplane gross weight is 2500 lbs, and the CG is 1 foot in front of the center of lift, that is a moment of 2500 foot-lbs. If the tail plane is 10 feet behind the center of lift, the force on the stabilizer is 250 lbs. Dean Now for fuel burn increases, factor in the induced drag created by the deflected elevator to create the required down force. Glider pilots attempt to maintain a CG at 75-85% MAC (some will go farther aft), to keep the deflection to create the required down force to a minimum to create the least amount of drag at cruising speed. huh? 75 to 85% MAC? I began to build one years ago and it's CG was in the "usual position" about 25% to 30%, depending on how much you had for lunch I can't see any of the competition gliders being able for a CG in that position either. not with the stab area that they have. A model glider with a massive stab, yes, but not any full size as far as I can see. Anything with a CG that far aft on the main plane is leaning more towards being a tandem wing aircraft than a conventional one. Can you provide an example of one of these? Bertie Bertie |
"BT" wrote in :
Bertie... perhaps I miss spoke.. correct.. not 85% MAC... but 85% towards the AFT CG limit.. Ah, 85% of the range, you mean? OK. In airliners we actually go for the aft limit, if possible. There's a double benefit from this. One, the drag from the stab is lowered and the effective weight of the aricraft is also lowered. But perhaps more importantly, the lower wing load resulting from the aft CG allows a wider buffet margin and therfore a higher allowable cruising level. One of the reasons that manufaturers want FBW systems is to permit flying with what would be an extreme aft CG for a standard airplane. This allows almost silly cruising levels at very, very low buffet margins to be had. The reason of course is the higher you go, the more fuel and $$$$ you save. Bertie |
I agree with your statement, but I don't know where the center of lift
is on GA airplanes, hence the question. Maybe it would have been better to ask a center of lift question. The loading moment is calculated from an arbitrary datum, it would be neat if there was an easily identifed point that corrosponded to the center of lift. On Nov 2, 5:52 pm, wrote: On Nov 2, 7:12 pm, Tina wrote: OK, so the center of gravity (except for some airplanes with really smart computers) is going to be forward of the center of lift for stall recovery reasons -- that makes sense. The question I have is, for a typical GA flying machine -- take a complex single for example -- what really is the download (I'm thinking of it as induced weight with fuel burn consequences) supplied by the vertical stabilizer? It has a reasonable moment arm hanging way back there, but is it as much as say 100 pounds if the CG is near the forward limit? This isn't an aeronautical problem, its a basic mechanics problem. The moment of the CG vs. the center of lift must equal the moment of the tail plane. If the airplane gross weight is 2500 lbs, and the CG is 1 foot in front of the center of lift, that is a moment of 2500 foot-lbs. If the tail plane is 10 feet behind the center of lift, the force on the stabilizer is 250 lbs. Dean |
Aeronautical Glossary | Big John | Piloting | 1 | October 24th 07 06:45 PM |
Are flight engineers qualified to fly? | Mxsmanic | Piloting | 14 | January 23rd 07 07:39 PM |
UBC's Human-Powered Helicopter blades questions (kinda technical,engineers welcome) | james cho | Rotorcraft | 1 | October 23rd 05 06:47 PM |
Old Aeronautical Charts | fr8rflyr | Aviation Marketplace | 0 | March 7th 04 05:16 AM |
Aeronautical Term | Nyal Williams | Restoration | 1 | August 4th 03 09:33 PM |
