When to descend II
Old November 9th 07, 01:58 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default When to descend II
"Bee" wrote in message ...
You don't have to abide by MVA as the minimum altitude prior to the fix at
which you clear me for a visual?
Not once the approach clearance is issued.
  #62
Old November 9th 07, 02:02 PM posted to rec.aviation.ifr
Steven P. McNicoll
He probably meant NW.
I don't think so. If he was northwest of ROYCE on the localizer the part of
his question about heading for the numbers once the visual approach
clearance is issued becomes moot.
  #63
Steven P. McNicoll
"John Godwin" wrote in message
Vectored, maybe but not navigating.
Navigating. Think GPS.
  #64
Old November 9th 07, 02:10 PM posted to rec.aviation.ifr
Steven P. McNicoll
If you were on vectors to the ILS, the final heading for intercept
couldn't be greater than 330 coming from that direction.
A 330 heading to join the localizer inbound would make an intercept angle of
about 160 degrees. That'd be a cute one.
  #65
Old November 9th 07, 02:13 PM posted to rec.aviation.ifr
Steven P. McNicoll
It was cross ROYCE at or above 2,000, *then* cleared for the visual.
No it wasn't. It was, "Cessna '1GS,cross ROYCE at or above 2 thousand,
cleared visual
approach runwy 12R. Contact the tower on 118.7.", issue when the aircraft
was four miles southwest of ROYCE.
  #66
Old November 9th 07, 02:16 PM posted to rec.aviation.ifr
Steven P. McNicoll
Apparently so. Nonetheless, the visual approach was not authorized until
*after* crossing ROYCE at or above 2,000.
Incorrect. No such restriction was issued. The clearance was effective the
instant it was issued.
Or, it could have been to assure MVA until ROYCE.
MVA is irrelevant once the visual approach clearance is issued.
  #67
Steven P. McNicoll
But, the clearance for the visual was for a future point in space; i.e.,
ROYCE, which was still to be crossed.
Incorrect.
  #68
Old November 9th 07, 02:18 PM posted to rec.aviation.ifr
Steven P. McNicoll
What the OP stated,
Approach says "Cessna '1GS,cross ROYCE at or above 2 thousand, cleared
visual approach runwy 12R. Contact the tower on 118.7."
I didn't say "future approach clearance." I said the present clearance
did not make the visual applicable until a future point in space.
And you're wrong each time you say it.
  #69
Old November 9th 07, 02:20 PM posted to rec.aviation.ifr
Steven P. McNicoll
He was cleared to ROYCE with an altitude.
Nothing on the OP's message required the aircraft to cross ROYCE.
  #70
Old November 9th 07, 02:23 PM posted to rec.aviation.ifr
Steven P. McNicoll
Not until you reach ROYCE and the visual approach clearance becomes
effective.
The visual approach clearance was effective the instant it was issued.
When to descend Dan Luke[_2_] Instrument Flight Rules 44 October 14th 07 09:12 AM
