National Airspace System (NAS) isn’t as safe as the FAA would have you believe
Old November 13th 07, 12:31 AM posted to rec.aviation.piloting
HilldaBeast
Default National Airspace System (NAS) isn’t as safe as the FAA would have you believe
NASA, with the help of it’s Aviation Safety Reporting System
(ASRS), a few thousand interviews and $8,500,000 dollars has
collected a stockpile of evidence that the National Airspace
believe. The media is catching on.
Officials at NASA are engaged in damage control, and well
they should be. The federal aeronautics and space agency has
risked its research credibility with its rationale for
sitting on the findings of an air-safety survey that took
years and $8.5 million to conduct. The Associated Press
reported this week that NASA had rejected its request for
data regarding the agency’s interviews with 24,000
commercial and private pilots. The NASA explanation for
withholding the findings cited the potential detriment to
the welfare of the airline industry and public confidence in
the aviation system.
Was it the idea, then, to maintain false confidence in
aviation safety by suppressing disturbing findings? The
agency’s chief administrator has since declared NASA never
would put industry profits ahead of issues of public safety.
If so, trying to keep a close secret was not the smartest
way to project public safety as first priority.
…The information gleaned by the Associated Press
suggests the pilot survey revealed more problems and
dangerous incidents than are reported to the Federal
Aviation Administration and other government agencies.
…NASA’s decision to sit on the findings is all the more
disturbing because the information would be an invaluable
addition to other well-documented concerns. Among these are
congested airways, outmoded equipment and a shortage of
experienced air-traffic controllers.
Old November 13th 07, 01:33 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default National Airspace System (NAS) isn’t as s afe as the FAA would have you believe
HilldaBeast wrote in news:uf6_i.958$8x6.464
@newsfe02.lga:
The FAA never told me it's safer than I thought it was.
that makes you a liar.
Bertie
Old November 13th 07, 01:38 PM posted to rec.aviation.piloting
Larry Dighera
On Mon, 12 Nov 2007 19:31:21 -0500, HilldaBeast
wrote in :
It appears that the "idea" was to refrain from releasing misleading
data:
http://technology.newscientist.com/c...ty-survey.html
The agency commissioned a telephone pollster to ask 29,000 pilots
about their near misses, runway collisions and technical problems.
At first, the poll seemed to show that these events had previously
been alarmingly under-reported. Engine failures, for instance,
were cited in NASA's survey at four times the rate recorded in the
Federal Aviation Administration's incident records.
The problem is that NASA appears to have counted some incidents
more than once. Pilots were given anonymity, so NASA can't tell
when several reports of an incident refer to the same event.
Explaining the gaffe to the House Committee on Science and
Technology on 31 October, NASA chief Mike Griffin admitted the
figures were "simply not credible".
"NASA can't tell when several reports refer to the same
event"
System Operation of Aircraft System [email protected] Instrument Flight Rules 1 October 12th 07 06:50 AM
GAO: Very Light Jets: Several Factors Could Influence Their Effect on the National Airspace System Mike[_7_] Naval Aviation 0 August 27th 07 06:45 PM
SMALL UAV OK'D FOR NATIONAL AIRSPACE Larry Dighera Piloting 11 June 25th 07 01:04 AM
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 09:35 PM
Two airspace classes for one airspace? (KOQU) John R Piloting 8 June 30th 04 04:46 AM
