You could get a prescription and then use a medical bottle, which has a
different fitting. They tend to be steel tanks, and heavy, and getting a four place regulator could be difficult. However, you could do the exchange thing, and it likely would be a lot cheaper. |
On Wed, 14 Nov 2007 19:46:39 GMT, Viperdoc wrote:
You could get a prescription and then use a medical bottle I distinctly remember reading that medical O2 was not acceptable (legal?) for aviation. Something about the humidity being too high and freezing in the valve. -- Dallas |
On Wed, 14 Nov 2007 17:39:19 -0600, Dallas wrote:
I distinctly remember reading that medical O2 was not acceptable (legal?) for aviation. Never mind. (I did read or hear someone say that... but it appears to incorrect.) Here's a good article: http://www.avweb.com/news/pelican/182079-1.html "Oxygen is oxygen. It is the substance that matters, not the intended purpose. These days, welding, medical, and aviation oxygen are exactly the same. All three come from the same tank of liquid oxygen (LOX). The liquified form is the cleanest, purest, driest form of oxygen (or any substance) you'll find anywhere." -- Dallas |
Dallas schrieb:
"Oxygen is oxygen. It is the substance that matters, not the intended purpose. These days, welding, medical, and aviation oxygen are exactly the same. All three come from the same tank of liquid oxygen (LOX). The liquified form is the cleanest, purest, driest form of oxygen (or any substance) you'll find anywhere." Sure. But you don't care about the oxygen in the manufactorer's tank, it's the oxygen in the bottle that you care about. It's the filling process which makes all the difference. |
![]() "Dallas" wrote in message ... On Wed, 14 Nov 2007 19:46:39 GMT, Viperdoc wrote: You could get a prescription and then use a medical bottle I distinctly remember reading that medical O2 was not acceptable (legal?) for aviation. Something about the humidity being too high and freezing in the valve. -- That's always been my take on it to Dallas, per our suppliers. Medical and industrial are filled from the same source. Aviation is essentially the same, but has to be dryer to avoid freezing in extremely low temps. Precautions taken to avoid impurities in the filling process might differ. But I bet there are some industrial OX users that are pretty picky about getting clean pure OX as well. Not everyone just uses it simply for welding and cutting. |
Maxwell schrieb:
But I bet there are some industrial OX users that are pretty picky about getting clean pure OX as well. Not everyone just uses it simply for welding and cutting. For those applications, the manufactorers offer *really* pure oxygen, which happens to cost even more than aviation O2. |
On Nov 14, 3:52 pm, "Maxwell" wrote:
"Dallas" wrote in message ... On Wed, 14 Nov 2007 19:46:39 GMT, Viperdoc wrote: You could get a prescription and then use a medical bottle I distinctly remember reading that medical O2 was not acceptable (legal?) for aviation. Something about the humidity being too high and freezing in the valve. -- That's always been my take on it to Dallas, per our suppliers. Medical and industrial are filled from the same source. Aviation is essentially the same, but has to be dryer to avoid freezing in extremely low temps. Precautions taken to avoid impurities in the filling process might differ. But I bet there are some industrial OX users that are pretty picky about getting clean pure OX as well. Not everyone just uses it simply for welding and cutting. According to the gas company I spoke with, all 3 grades of O2 come from the same source. Medical O2 adds the moisture after the O2 comes from the bottle (to avoid drying people out). The difference (according to the gas company) is the certification. When they fill an aviation bottle they must test it for use in aviation. That test results in a certification of the O2 in the bottle. I'm not sure if the FBO's do that or if they are somehow able to certify their main bottles. -Robert |
Robert M. Gary wrote:
When they fill an aviation bottle they must test it for use in aviation. That test results in a certification of the O2 in the bottle. I'm not sure if the FBO's do that or if they are somehow able to certify their main bottles. -Robert The test is done at the gas plant where the bottles are filled. If the whole batch passes, the tanks pass too. The FBO's involvement is getting the bottles delivered by the vendor, using the bottles, and having the bottles picked back up by the vendor. Medical Grade handling changed about 10 years ago. Now exhausted medical bottles are sucked to vacuum to remove any possible contamination. Then they are filled at the gas plant. The bottles have serial numbers. There is record keeping. This adds to the cost. From $2/month bottle rental to $10/month bottle rental. Before 10 years ago, filling a medical bottle was no different than filling a welding bottle or filling an aviation bottle. You hooked up, you filled, you went and used it. If you NEVER let the small bottle go completely empty, and keep what the medical industry called a "safe residual" pressure (200 psi)in it, contaminants would never enter the system. The whole change in medical bottle handling was to fix a "problem" that was caused by misuse in the first place, and really wasn't a problem in the first place if you didn't leave an empty bottle OPEN to atmosphere for days on end. You can buy a little two bottle cart at a welding shop, put two M cylinders of medical or welding grade.. your choice.. put a little manifold and filling pigtail.. and stand it in the corner of your garage, and chain it upright for safety. You will have at least as safe transfilling as was acceptable in the medical industry for YEARS until recently. |
Dallas wrote:
Something about the humidity being too high and freezing in the valve. THIS IS PURE BS. There is essentially NO moisture in the tank of medical oxygen - for the same reasons there is no moisture in aviation or welders oxygen. Any moisture or humidification in a medical stream is added at the point of use, AFTER the flowmeter. Any doctor, nurse, paramedic, EMT, respiratory therapist or gas vendor can vouch for this. Dave |
Probably only a gas vendor would know.
Anybody ask one???? Dave S wrote: Dallas wrote: Something about the humidity being too high and freezing in the valve. THIS IS PURE BS. There is essentially NO moisture in the tank of medical oxygen - for the same reasons there is no moisture in aviation or welders oxygen. Any moisture or humidification in a medical stream is added at the point of use, AFTER the flowmeter. Any doctor, nurse, paramedic, EMT, respiratory therapist or gas vendor can vouch for this. Dave |
Filling Aluminum | Lou | Home Built | 3 | December 27th 06 02:41 AM |
Filling with nitrogen | scott moore | Owning | 21 | December 8th 06 07:48 PM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 28th 04 11:41 PM |
Minden's filling up! | JJ Sinclair | Soaring | 12 | February 15th 04 11:46 AM |
