On Nov 17, 6:10 pm, Dan wrote:
On Nov 17, 2:16 pm, "Matt W. Barrow" wrote: "Dan" wrote in message ... On Nov 15, 10:39 pm, "Matt W. Barrow" wrote: "Dan" wrote in message ... So short of doing your own transfilling, where does everyone get cheap O2? Or are you paying big bucks at the FBOs? For an occasional user, the transfilling equipment does not make sense. An Oxygen optimizer (i.e., Mountain High or Aerox) makes your tank full of O2 last about six to ten times longer than a normal system. Filling your own and an Optimizer brings the cost of O2 down to near zero. Further, it makes it worthwhile to use higher altitudes that an expensive system make prohibitive. Would it be worth it in a non-turbo aircraft? (ie. 182, Comanche?) I live out west and have been debating for a while. As with so many other points, it depends. First, I find it rather odd that someone would have built in O tanks in a non-turbo aircraft. Also, much depends on WHY you want to go high: terrain, distance, favorable winds... When I lived in Montrose, CO, every flight pretty muh dictated going high, often 15K or 16K feet to get over the mountains and over to the front range. Added to this was most flights were 350 or more miles. If you do use oxygen fairly often, check the prices on the O conservers and do the math to see if it's worthwhile. Also, add in your fuel saving in going higher. Anyone know of a good place that fills tanks in the Phoenix area? Call around to some welding supply stores, but don't tell them it's for an aircraft, just tell them you're doing to fancy artwork welding. :~) -- Matt Barrow Performance Homes, LLC. Cheyenne, WY- Hide quoted text - - Show quoted text - Matt, It would be a portable system. I am in a club with a 182 and a Comanche 260. The main purpose of the O2 would be to get to MEAs over high terrain enabling me to go IFR on those flights. Of course, the manual says the ceiling on the Comanche is FL210, and the 182 is 18k, however not having Oxygen, I am not sure how practical it is to go much above 12.5k in those aircraft... I find that in my plane it is rare that I can fly IFR (at least IMC) at those altitudes because of ice. -Robert |
On Nov 17, 7:47 pm, "Robert M. Gary" wrote:
On Nov 17, 6:10 pm, Dan wrote: On Nov 17, 2:16 pm, "Matt W. Barrow" wrote: "Dan" wrote in message ... On Nov 15, 10:39 pm, "Matt W. Barrow" wrote: "Dan" wrote in message ... So short of doing your own transfilling, where does everyone get cheap O2? Or are you paying big bucks at the FBOs? For an occasional user, the transfilling equipment does not make sense. An Oxygen optimizer (i.e., Mountain High or Aerox) makes your tank full of O2 last about six to ten times longer than a normal system. Filling your own and an Optimizer brings the cost of O2 down to near zero. Further, it makes it worthwhile to use higher altitudes that an expensive system make prohibitive. Would it be worth it in a non-turbo aircraft? (ie. 182, Comanche?) I live out west and have been debating for a while. As with so many other points, it depends. First, I find it rather odd that someone would have built in O tanks in a non-turbo aircraft. Also, much depends on WHY you want to go high: terrain, distance, favorable winds... When I lived in Montrose, CO, every flight pretty muh dictated going high, often 15K or 16K feet to get over the mountains and over to the front range. Added to this was most flights were 350 or more miles. If you do use oxygen fairly often, check the prices on the O conservers and do the math to see if it's worthwhile. Also, add in your fuel saving in going higher. Anyone know of a good place that fills tanks in the Phoenix area? Call around to some welding supply stores, but don't tell them it's for an aircraft, just tell them you're doing to fancy artwork welding. :~) -- Matt Barrow Performance Homes, LLC. Cheyenne, WY- Hide quoted text - - Show quoted text - Matt, It would be a portable system. I am in a club with a 182 and a Comanche 260. The main purpose of the O2 would be to get to MEAs over high terrain enabling me to go IFR on those flights. Of course, the manual says the ceiling on the Comanche is FL210, and the 182 is 18k, however not having Oxygen, I am not sure how practical it is to go much above 12.5k in those aircraft... I find that in my plane it is rare that I can fly IFR (at least IMC) at those altitudes because of ice. -Robert- Hide quoted text - - Show quoted text - If going above 12.5k gets you on top, then it might be worth it. --Dan |
On Nov 17, 6:51 pm, Dan wrote:
On Nov 17, 7:47 pm, "Robert M. Gary" wrote: On Nov 17, 6:10 pm, Dan wrote: On Nov 17, 2:16 pm, "Matt W. Barrow" wrote: "Dan" wrote in message ... On Nov 15, 10:39 pm, "Matt W. Barrow" wrote: "Dan" wrote in message ... So short of doing your own transfilling, where does everyone get cheap O2? Or are you paying big bucks at the FBOs? For an occasional user, the transfilling equipment does not make sense. An Oxygen optimizer (i.e., Mountain High or Aerox) makes your tank full of O2 last about six to ten times longer than a normal system. Filling your own and an Optimizer brings the cost of O2 down to near zero. Further, it makes it worthwhile to use higher altitudes that an expensive system make prohibitive. Would it be worth it in a non-turbo aircraft? (ie. 182, Comanche?) I live out west and have been debating for a while. As with so many other points, it depends. First, I find it rather odd that someone would have built in O tanks in a non-turbo aircraft. Also, much depends on WHY you want to go high: terrain, distance, favorable winds... When I lived in Montrose, CO, every flight pretty muh dictated going high, often 15K or 16K feet to get over the mountains and over to the front range. Added to this was most flights were 350 or more miles. If you do use oxygen fairly often, check the prices on the O conservers and do the math to see if it's worthwhile. Also, add in your fuel saving in going higher. Anyone know of a good place that fills tanks in the Phoenix area? Call around to some welding supply stores, but don't tell them it's for an aircraft, just tell them you're doing to fancy artwork welding. :~) -- Matt Barrow Performance Homes, LLC. Cheyenne, WY- Hide quoted text - - Show quoted text - Matt, It would be a portable system. I am in a club with a 182 and a Comanche 260. The main purpose of the O2 would be to get to MEAs over high terrain enabling me to go IFR on those flights. Of course, the manual says the ceiling on the Comanche is FL210, and the 182 is 18k, however not having Oxygen, I am not sure how practical it is to go much above 12.5k in those aircraft... I find that in my plane it is rare that I can fly IFR (at least IMC) at those altitudes because of ice. -Robert- Hide quoted text - - Show quoted text - If going above 12.5k gets you on top, then it might be worth it. I don't mind flying above (or sometimes in) the ice if I have low MEA's below me. However, I don't like to do it through the mountains when there is wide spread IMC. If the IMC is just scattered them I'd go VFR. Of course our MEA's are in the 15K's. -Robert |
Filling Aluminum | Lou | Home Built | 3 | December 27th 06 02:41 AM |
Filling with nitrogen | scott moore | Owning | 21 | December 8th 06 07:48 PM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 28th 04 11:41 PM |
Minden's filling up! | JJ Sinclair | Soaring | 12 | February 15th 04 11:46 AM |
