"Todd W. Deckard" wrote: It *is* interesting to me that consumer electronics provide this capability. I dunno. Single accelerometers with no integration logic are pretty cheap. Macbooks have had them for some time now. They are used to park the hard drive head if you drop the machine. There's also a dashboard widget you can install that displays the accelerometer reading as a bubble level, which is kinda cool, and much more appropriate IMO than an aviation-style display. http://www.apple.com/downloads/dashb...carpentersleve l.html in case you're interested. Between the camera, and the more expensive R/C helicopters which have a stability augmentation system like a yaw damper (which uses an actual spinning gyro) this stuff is coming into reach of a cockpit mountable capability. Yes. I already noted that such devices are already on the market: http://www.icarusinstruments.com/microEFIS.html It costs about $1500 (which, interestingly, is about the same as a middle-of-the-line Macbook). A bigger crime to be debated is the "psuedo" panel display afforded by some of the handheld GPS units. It derives bearing and attitude information from the apparant change in flight path. I have heard folks speculate that this could be used in instrument flight after failure of the AI/HI? I actually tried this a while back in a 182 and a handheld GPS. It works actually much better than a single accelerometer (which is pretty much guaranteed to kill you). If you are very, very careful you can keep the plane kinda sorta level for quite a while. But it's mentally exhausting, and I certainly would not want to rely on it in IMC. rg |
backup for vacuum pump/attitude indicator failure | Kelly | Owning | 27 | November 29th 06 06:58 AM |
backup for vacuum pump/attitude indicator failure | Kelly | Instrument Flight Rules | 26 | November 29th 06 06:58 AM |
Backup AI (using solid state gyro) for portable | Andrew Gideon | Piloting | 14 | January 27th 05 08:41 AM |
Backup AI (using solid state gyro) for portable | Andrew Gideon | Products | 13 | January 27th 05 08:41 AM |
gradual gyro failure in FS2004? | Gary L. Drescher | Simulators | 3 | July 19th 03 07:07 AM |
