On Sun, 23 Dec 2007 07:16:11 -0600, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . I believe the point here is, that it's incumbent on the VFR PIC to explicitly _REQUEST_ clearance into Class B airspace every time (instead of saying "with you" or some such): It's incumbent on the PIC to receive an ATC clearance that allows entry to the Class B airspace before operating his aircraft in that area, doesn't matter if he's operating VFR or IFR. Agreed. But it does matter if the PIC fails to REQUEST clearance into Class B, or for a procedure that necessitates navigation through Class B. The request puts the onus of regulation compliance more squarely on the shoulders of ATC, who can at times forget to explicitly issue a clearance. In those rare situations, if a PD should happen to be filed, it would be much more clear that the PIC knew he needed to be cleared, and the controller erred. |
Class B airspace notation | BillJ | Piloting | 59 | December 27th 07 12:48 AM |
Transponders Above Class C Airspace | Jim Vincent | Soaring | 20 | May 15th 07 04:36 PM |
Class F Airspace in Germany | Guy Corbett | Soaring | 4 | May 9th 07 09:25 AM |
Class A airspace | flying_monkey | Soaring | 66 | October 22nd 06 03:38 PM |
Tower with only Class G Airspace | Jeff Saylor | Piloting | 8 | May 10th 04 09:53 PM |
