engine pre-oiler
Old December 31st 07, 04:04 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
Default engine pre-oiler
Maxwell: The engine is installed in my Baby Belle helicopter. It has a dry
sump located just below the accesory case and a flat plate replaces the
normal cast sump which contained the intake manifold. A new intake manifold
was constructed, drain tubes made for the valve covers and an oil return was
fashioned connected to the accesory case. Works like gangbusters so far
(230hrs). If you want I could snap a shot and send them to you via e-mail?
Stu
"Maxwell" wrote in message
On Dec 30, 2:04 pm, "Maxwell" wrote:
Yep in some ways the accumulator looks good except it does take up a
bit
of space.
Yeah, and useless if you forget to reset it during shutdown, and limited
to
about a quart of prime.
A quart of prime would be six or eight times as much as is needed
to preoil the engine. My little hand-pump on my A-65 does it with ten .
75 cubic-inch strokes, for 7.5 cu. in. total. A larger engine might
take 10 or 12 cubic inches. An engine tighter than mine (61 years old
now) would take much less.
A quart has just under 58 cubic inches.
You got any photos of that rig?
Old December 31st 07, 04:18 PM posted to rec.aviation.homebuilt
Maxwell
"Stuart & Kathryn Fields" wrote in message
dry sump located just below the accesory case and a flat plate replaces
the normal cast sump which contained the intake manifold. A new intake
manifold was constructed, drain tubes made for the valve covers and an oil
return was fashioned connected to the accesory case. Works like
gangbusters so far (230hrs). If you want I could snap a shot and send
That's ok Stu, I have a pretty good idea what your installation looks like.
I was trying to picture the installation Dan keeps referring to.
Old December 31st 07, 04:47 PM posted to rec.aviation.homebuilt
On Dec 31, 9:18 am, "Maxwell" wrote:
"Stuart & Kathryn Fields" wrote in messagenews:uqGdnbOh57S2juTanZ2dnUVZ_qGknZ2d@iwvis p.com...
None so far. Next time I have the cowling off I'll take
some, and then I'll have to set up some account somewhere to post
them.
Dan
Engine-out procedures and eccentric forces on engine pylons Mxsmanic Piloting 18 May 26th 07 01:03 AM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
Preheat / Pre-Oiler Fastglasair Home Built 6 November 13th 04 05:40 AM
Preheat / Pre-Oiler Fastglasair Owning 1 November 11th 04 05:11 PM
