i think I flew into class c airspace accidentally withoutestablishing communication
Old January 29th 08, 04:55 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
Default i think I flew into class c airspace accidentally without establishingcommunication
Steven P. McNicoll wrote:
"Gig 601XL Builder" wrote in message
You said use of a VOR was in the PP requirements. It's not.
It was for me.
No it wasn't.
Yes it was. I had no other electronic nav system in the aircraft I took my
PPL checkride in.
No it wasn't. The PP requirements are not altered by the equipment in the
aircraft used for the checkride.
Your sound more like MX every time you touch your keyboard.
Let's try something.
A. Is there a requirement in the PP standard to show use of a electronic
navigation system?
If Yes go to B.
If No you're an idiot I already posted the requirement.
B. If VOR is the only electronic navigation system in the plane how will
one be tested on an ADF, GPS or anything else?
Old January 30th 08, 12:22 AM posted to rec.aviation.piloting
Steven P. McNicoll
Default i think I flew into class c airspace accidentally without establishing communication
navigation system?
Yes.
If Yes go to B.
They won't be tested on anything else.
Has this little exercise helped you to understand that use of a VOR is not
in the PP requirements, and that the PP requirements are not altered by the
equipment in the
aircraft used for the checkride?
If "No", you're an idiot.
Old January 30th 08, 10:22 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Steven P. McNicoll" wrote in
electronic navigation system?
Yes.
If Yes go to B.
will one be tested on an ADF, GPS or anything else?
not in the PP requirements, and that the PP requirements are not
Actually, the examiner isn't some automaton who sits there checking
boxes. (well there're probably one or two who do)
If he gets into an airplane with a candidate who can't operate the ****
on board and he imagines this guy putting around like a cow on crack,
long fingering the day he might learn to use the equipment installed,
he's going to fail him on general princple.
He won't say that, of course....
Bertie
Old January 30th 08, 05:46 PM posted to rec.aviation.piloting
Christopher Brian Colohan
Bertie the Bunyip writes:
I don't know if my interpretation of the legaleese is correct, but
when I did my test my instructor told me "if it is on the panel, the
examiner will expect you to know how to use it, or at a bare minimum
how to disable it."
So he taught me how to use the GPS that was installed in my club's
Tomahawks. My examiner had no issues at all when I hit the "direct to
nearest" buttons on the GPS when he asked me what I would do if I was
to divert to the closest airport.
Chris
Old January 30th 08, 06:12 PM posted to rec.aviation.piloting
Christopher Brian Colohan wrote in
how to disable it."
Well, it's a bit more than that. Unless youre in an airplane you never flew
before ,he will be looking to see you know how to operate it and all it's
junk safely. It's more of a feeling thing. If you make him feel like he'd
let his kids ride with you after the checkride, he'll sign the piece of
paper.
If a candidate can't be bothered to spend the 15 minutes it takes to learn
how to use a VOR, believe me, he'll know.
Bertie
Class B airspace notation BillJ Piloting 59 December 27th 07 12:48 AM
Class A airspace flying_monkey Soaring 66 October 22nd 06 03:38 PM
Class C Airspace Discussion Mike Granby Piloting 48 April 18th 06 12:25 AM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 02:53 PM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
