How did KPHX Class B get so screwed up?
Old January 31st 08, 08:38 AM posted to rec.aviation.piloting
Default How did KPHX Class B get so screwed up?
On Jan 31, 5:35*am, Mxsmanic wrote:
What is happening to the FAA? *The new Class B airspace at KPHX drives another
few nails into the GA coffin.
Huh? Why, explain.
Old January 31st 08, 01:53 PM posted to rec.aviation.piloting
John[_13_]
Not true at all, handheld GPS moving map units can be had for as little as
300.00 less if used. and non aviation units for less then 100.00. If you
don't know the area then you had better have one. But looking at the chart
there are lots of places where the airspace does not get restricted until
3000 feet giving you plenty of room go under the class b airspace. Just
because you can't do it does not mean anyone else would have a issue with
it. You simply don't have a valid point of reference.
"Mxsmanic" wrote in message
writes:
On Jan 31, 5:35 am, Mxsmanic wrote:
What is happening to the FAA? The new Class B airspace at KPHX drives
another
Huh? Why, explain.
Because it depends so much on moving-map navigation systems, rather than
just
VORs and radials or landmarks. If you don't have a fancy glass display
that
shows exactly where you are, you can easily bust the Class B without
realizing
it. In previous configurations, you could use PXR to keep you out of
trouble
through a large part of the airspace as long as you had a VOR receiver and
DME. Now you can't. Given the cost of advanced moving-map systems, many
GA
aircraft aren't going to have them, and this new configuration seems to be
a
deliberate attempt to keep GA aircraft in this category out of the
airspace.
Old January 31st 08, 02:12 PM posted to rec.aviation.piloting
On Jan 31, 1:49*pm, Mxsmanic wrote:
writes:
Huh? Why, explain.
Because it depends so much on moving-map navigation systems, rather than just
VORs and radials or landmarks. *If you don't have a fancy glass display that
shows exactly where you are, you can easily bust the Class B without realizing
it. *In previous configurations, you could use PXR to keep you out of trouble
DME. *Now you can't. *Given the cost of advanced moving-map systems, many GA
aircraft aren't going to have them, and this new configuration seems to be a
deliberate attempt to keep GA aircraft in this category out of the airspace.
I think you are right if all above's 'you' will be replaced by
'Mxsmanic'
-Kees
Old January 31st 08, 10:03 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
VORs and radials or landmarks. If you don't have a fancy glass display that
it.
I have successfully navigated around the new curved portions of the PHX
class B without a GPS, or a DME (hahaha!). Those of us that actually fly
were taught how to navigate using a chart. It's no different from navigating
around the class B before they changed it.
You are a such a tool.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200801/1
Old January 31st 08, 11:56 PM posted to rec.aviation.piloting
* *I have successfully navigated around the new curved portions of the PHX
class B without a GPS, or a DME (hahaha!). * Those of us that actually fly
were taught how to navigate using a chart. *It's no different from navigating
Exactly. Being able to tell where you are with basic pilotage skills
and a chart is an essential part of being a pilot, it's part of the
PTS, and it's tested during the checkride.
Well, you don't NEED a checkride for MSFS.
How did KPHX Class B get so screwed up? Larry Dighera Piloting 19 February 2nd 08 09:49 AM
Controller screwed up? Paul Tomblin Piloting 51 September 14th 07 09:59 PM
PSS 747 Depature Route from KPHX Thomas Simulators 0 July 19th 04 11:52 AM
Don't Want to be Screwed [email protected] Home Built 5 May 22nd 04 06:58 AM
Changes At KPHX Jay Beckman Piloting 5 April 6th 04 03:31 PM
