On Feb 19, 3:06 pm, "Ken S. Tucker" wrote:
Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. If we could do it once we'd be flying some cheap simulator. You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto the pavement. tends to break airplanes. You cannot stall an airplane with the relative wind at such a low angle as you claim. Period. Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is hard on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it poses the risk of wheelbarrowing, meaning a complete loss of control. So much baloney. Even a ten-hour student can spot this as such. Dan |
Hi BIG HEAD, I'll give you a "B" on your post.
It lacks detail, see below... On Feb 19, 9:14 pm, wrote: On Feb 19, 3:06 pm, "Ken S. Tucker" wrote: Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. If we could do it once we'd be flying some cheap simulator. You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto the pavement. tends to break airplanes. You cannot stall an airplane with the relative wind at such a low angle as you claim. Period. Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is hard on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it poses the risk of wheelbarrowing, meaning a complete loss of control. So much baloney. Even a ten-hour student can spot this as such. Dan Sorry Dan, you don't know how to land aircraft, most pilots don't so don't feel like your centered out. I find the C152 a bit better than the C150, I guess cuz a bit more engine weight in the nose, subtle shift in CG vs CL, you know. So go over the numbers and do the flare + pitch. The horny should be going, and pull the yoke back easy to maintain a constant horny. Yangooooo.....listen.... Then nudge yoke foward. If the landing is super you can't even feel the nose wheel touching down. ((I know about porposing, if the landing sucks then hit the throotle, SOP)). You know what your problem is Dan, your a loser, you've never do a fantastic landing in your life, if you ever have done one you'd know what we're talking about. Best Landings though... Ken |
On Feb 21, 10:34*am, "Ken S. Tucker" wrote:
Hi BIG HEAD, I'll give you a "B" on your post. It lacks detail, see below... On Feb 19, 9:14 pm, wrote: On Feb 19, 3:06 pm, "Ken S. Tucker" wrote: Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. * * * * * *If we could do it once we'd be flying some cheap simulator. *You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto the pavement. tends to break airplanes. You cannot stall an airplane with the relative wind at such a low angle as you claim. Period. * * * Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is hard on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it *poses the risk of wheelbarrowing, meaning a complete loss of control. * * * * So much baloney. Even a ten-hour student can spot this as such. * * * *Dan Sorry Dan, you don't know how to land aircraft, most pilots don't so don't feel like your centered out. I find the C152 *a bit better than the C150, I guess cuz a bit more engine weight in the nose, subtle shift in CG vs CL, you know. So go over the numbers and do the flare + pitch. The horny should be going, and pull the yoke back easy to maintain a constant horny. Yangooooo.....listen.... Then nudge yoke foward. If the landing is super you can't even feel the nose wheel touching down. ((I know about porposing, if the landing sucks then hit the throotle, SOP)). You know what your problem is Dan, your a loser, you've never do a fantastic landing in your life, if you ever have done one you'd know what we're talking about. So, you are advocating not following the POH? Cheers |
On Feb 20, 2:55 pm, WingFlaps wrote:
On Feb 21, 10:34 am, "Ken S. Tucker" wrote: Hi BIG HEAD, I'll give you a "B" on your post. It lacks detail, see below... On Feb 19, 9:14 pm, wrote: On Feb 19, 3:06 pm, "Ken S. Tucker" wrote: Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. If we could do it once we'd be flying some cheap simulator. You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto the pavement. tends to break airplanes. You cannot stall an airplane with the relative wind at such a low angle as you claim. Period. Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is hard on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it poses the risk of wheelbarrowing, meaning a complete loss of control. So much baloney. Even a ten-hour student can spot this as such. Dan Sorry Dan, you don't know how to land aircraft, most pilots don't so don't feel like your centered out. I find the C152 a bit better than the C150, I guess cuz a bit more engine weight in the nose, subtle shift in CG vs CL, you know. So go over the numbers and do the flare + pitch. The horny should be going, and pull the yoke back easy to maintain a constant horny. Yangooooo.....listen.... Then nudge yoke foward. If the landing is super you can't even feel the nose wheel touching down. ((I know about porposing, if the landing sucks then hit the throotle, SOP)). You know what your problem is Dan, your a loser, you've never do a fantastic landing in your life, if you ever have done one you'd know what we're talking about. So, you are advocating not following the POH? Cheers What's a POH? Ken |
"Ken ****head Tucker" took his dick out of his
mouth and wrote in : What's a POH? Ken What a dumb **** you are. All your talk about landing an airplane and you have no idea what a POH is. Even a sim moron knows what that is. |
On Feb 21, 7:06*pm, "Ken S. Tucker" wrote:
On Feb 20, 2:55 pm, WingFlaps wrote: On Feb 21, 10:34 am, "Ken S. Tucker" wrote: Hi BIG HEAD, I'll give you a "B" on your post. It lacks detail, see below... On Feb 19, 9:14 pm, wrote: On Feb 19, 3:06 pm, "Ken S. Tucker" wrote: Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. * * * * * *If we could do it once we'd be flying some cheap simulator. *You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto the pavement. tends to break airplanes. You cannot stall an airplane with the relative wind at such a low angle as you claim. Period. * * * Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is hard on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it *poses the risk of wheelbarrowing, meaning a complete loss of control. * * * * So much baloney. Even a ten-hour student can spot this as such. * * * *Dan Sorry Dan, you don't know how to land aircraft, most pilots don't so don't feel like your centered out. I find the C152 *a bit better than the C150, I guess cuz a bit more engine weight in the nose, subtle shift in CG vs CL, you know. So go over the numbers and do the flare + pitch. The horny should be going, and pull the yoke back easy to maintain a constant horny. Yangooooo.....listen.... Then nudge yoke foward. If the landing is super you can't even feel the nose wheel touching down. ((I know about porposing, if the landing sucks then hit the throotle, SOP)). You know what your problem is Dan, your a loser, you've never do a fantastic landing in your life, if you ever have done one you'd know what we're talking about. So, you are advocating not following the POH? Cheers What's a POH? Oh you've really blown it. Bertie will be wetting himself with laughter. Cheers |
WingFlaps wrote in
: On Feb 21, 7:06*pm, "Ken S. Tucker" wrote: On Feb 20, 2:55 pm, WingFlaps wrote: On Feb 21, 10:34 am, "Ken S. Tucker" wrote: Hi BIG HEAD, I'll give you a "B" on your post. It lacks detail, see below... On Feb 19, 9:14 pm, wrote: On Feb 19, 3:06 pm, "Ken S. Tucker" wrote: Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. * * * * * *If we could do it once we'd be flying some ch eap simulator. *You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto th e pavement. tends to break airplanes. You cannot stall an airplane wit h the relative wind at such a low angle as you claim. Period. * * * Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is ha rd on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it *poses the risk of wheelbarrowing, meaning a complete loss of control. * * * * So much baloney. Even a ten-hour student can spot th is as such. * * * *Dan Sorry Dan, you don't know how to land aircraft, most pilots don't so don't feel like your centered out. I find the C152 *a bit better than the C150, I guess cuz a bit more engine weight in the nose, subtle shift in CG vs CL, you know. So go over the numbers and do the flare + pitch. The horny should be going, and pull the yoke back easy to maintain a constant horny. Yangooooo.....listen.... Then nudge yoke foward. If the landing is super you can't even feel the nose wheel touching down. ((I know about porposing, if the landing sucks then hit the throotle, SOP)). You know what your problem is Dan, your a loser, you've never do a fantastic landing in your life, if you ever have done one you'd know what we're talking about. So, you are advocating not following the POH? Cheers What's a POH? Oh you've really blown it. Bertie will be wetting himself with laughter. Ken always makes me laugh. He's like Jerry Lewis on acid. Bertie |
On 21 Feb, 06:06, "Ken S. Tucker" wrote:
On Feb 20, 2:55 pm, WingFlaps wrote: On Feb 21, 10:34 am, "Ken S. Tucker" wrote: Hi BIG HEAD, I'll give you a "B" on your post. It lacks detail, see below... On Feb 19, 9:14 pm, wrote: On Feb 19, 3:06 pm, "Ken S. Tucker" wrote: Seriously tho Dud, I think you screwed up stall landings visa-vis AoA over the runway. I pull back the yoke for a perfect flare, and as the stall begins, my nose drops, then I nudge back the yoke a bit more to settle my little machine pretty much level and stalled simultaneously....bingo! At the moment before touch-down push the yoke easy forward and I do a 3 point landing at less than stall speed. Dud, take your machine out to do some touch and go's, and do 3 point landings at less than stall. It's an awesome feeling. It's so smooth you might not know you're on the pavement, when you do it really well, no guff. If you can do it once you'll know what I'm talking about. * * * * * *If we could do it once we'd be flying some cheap simulator. *You will NOT do a full stall landing placing all three wheels of a trike on the runway at once, unless you managed to flare at 20 feet and ran out of airspeed and dropped straight down onto the pavement. tends to break airplanes. You cannot stall an airplane with the relative wind at such a low angle as you claim. Period. * * * Besides, landing all three wheels at once is VERY poor technique. It means a landing made at rather high speed, which is hard on tires, brakes, and the rest of the airplane if you happen to run out of runway. It'd also dangerous, since it *poses the risk of wheelbarrowing, meaning a complete loss of control. * * * * So much baloney. Even a ten-hour student can spot this as such. * * * *Dan Sorry Dan, you don't know how to land aircraft, most pilots don't so don't feel like your centered out. I find the C152 *a bit better than the C150, I guess cuz a bit more engine weight in the nose, subtle shift in CG vs CL, you know. So go over the numbers and do the flare + pitch. The horny should be going, and pull the yoke back easy to maintain a constant horny. Yangooooo.....listen.... Then nudge yoke foward. If the landing is super you can't even feel the nose wheel touching down. ((I know about porposing, if the landing sucks then hit the throotle, SOP)). You know what your problem is Dan, your a loser, you've never do a fantastic landing in your life, if you ever have done one you'd know what we're talking about. So, you are advocating not following the POH? Cheers What's a POH? **** Off Hillbilly Bertie |
![]() "Ken S. Tucker" wrote in message ... So, you are advocating not following the POH? Cheers What's a POH? Ken Ah. He may be a good troll, but he's not a real pilot. -c |
Stall Recovery | Danny Deger | Piloting | 12 | January 30th 07 01:01 AM |
stall strips ??? | Tri-Pacer | Owning | 6 | December 8th 06 06:18 PM |
Bad place to stall | Stubby | Piloting | 23 | June 21st 05 04:10 PM |
Wing Stall | PaulaJay1 | Owning | 18 | December 11th 03 07:46 PM |
Stall resistant 172? | Roger Long | Piloting | 19 | October 18th 03 11:48 PM |
