"Frank Stutzman" wrote in message
... Dan wrote: JPI mentions GAMInjectors as required for the Lean of Peak method. Which is just one way the JPI manual is flat wrong. The big radial engines in airline use were run LOP as SOP. That was way before fuel injection. I can run my carbed E-225 LOP (although only about 20 degrees before it gets too rough) as can lots of other carbed engines. It may take some induction tuning or playing with carb heat to make it happen though. True!, and Deakin emphasizes that point, but the context is that the radial engines, due to their design, had more even fuel flow/distribution, even with carburetors. Currently, the Jacobs 755 radial has a single updraft carburetor and thus has fuel distribution on par with a HO layout. They recently got approval to replace the single carburetor with a FI unit and they report it's "turbine smooth". Now, Newps says he runs significantly LOP without GAMI's, but his is, I believe, an anomaly. OTOH, my old TNIO-550 ran smooth right up to fuel cutoff with GAMI's, and like a La-z-boy vibrator without them! :~) |
Why is LOP (lean of peak) controversial? | Andrew Gideon | Owning | 54 | October 2nd 06 08:11 PM |
TSIO 360 EB running lean at 12000 | Silvio Mecucci | Piloting | 12 | August 9th 05 11:39 PM |
Lean of Peak video | Roger Long | Piloting | 7 | August 24th 04 09:46 AM |
Lean of Peak Test Flight | Roger Long | Piloting | 0 | April 22nd 04 10:13 AM |
Fuel economy help | G.R. Patterson III | Owning | 10 | January 22nd 04 07:49 PM |
