On Mar 24, 7:01 am, Peter Clark
wrote: On Sun, 23 Mar 2008 21:21:21 -0700 (PDT), Sushidot wrote: On Mar 23, 2:31 pm, Peter Clark wrote: On Sun, 23 Mar 2008 13:29:53 -0700 (PDT), Sushidot wrote: Hello- I am a student pilot getting studying for my checkride. One question that I want to get right is the issue mentioned in the subject header above. My instructor said that because we do not have a MEL, we use the POH and anything that is considered Optional but is defective can be deferred and the flight could be made. There are three ohter designations in the Equipment list, "A" for additional, "S" for substitiuded and "R" for required. I would think that the "A" stuff probably could be deffered as well (ie AC equipment, autopilot, etc). I am a bit unclear and wanted some clarification on this from the group. Does this mean to refer to the equip list in the POH and anything with the letter "O" or optional that is defective can be deferred and the flight can be continued? Or can the stuff "A" and "O" be deferred. Anything that is not R in the equipment list or required by the rules the flight will be conducted under (day/VFR, night/IFR, whatever) can be dispatched when broken in the absense of a KOEL (Kind of Operation Equipment List) or MEL (FAA approved Minimum Equipment List). For example the co-pilot seat is S (Standard), pilot seat is R (Required), so as long as nobody is in the seat (or it's removed from the aircraft) the copilot seat is not needed. Don't forget about marking the defective equipment as such, deactivating or removing it from the aircraft, and making an appropriate mainteance log entry (see 91.213(3)). Weight and ballance may change if you are removing the defective part. Thank you for the Reply... This may be a dumb question, but what exactly is a KOEL? I came across this term twice and sorta assume its the equipment list in the POH...is that true or is it an additional list issued by the manufacturer ? A KOEL (Kind of Operation Equipment List) is an additional list in the POH's Limitations section which shows equipment required per flight rules in a tabular form. I've seen it in the new G1000 Cessna POHs, as well as the Malibu and Meridian, I'm sure there are others. With no MEL you go there first and if the equipment isn't listed there then you go to the equipment list. For exaple, the Malibu has two vaccum pumps, per the KOEL you can dispatch for VFR/IFR with one operational, but you need both operational for flight into icing (since the pumps also operate the de-ice boots). Peter- Thank you. I will check the POH for the KOEL. Here is another question...what does the H2AD mean for the Lycomming o-320-h2ad as well as the "o" in the front of the 320? Thanks JCL |
Cessna 172N with 0-320-H2AD | Paul | Owning | 6 | November 3rd 10 05:43 AM |
equipment list? | Tim | Owning | 30 | March 8th 07 11:46 PM |
Equipment List Required Documentation | O. Sami Saydjari | Owning | 9 | April 21st 04 02:57 AM |
FS: 1979 Cessna 172N, Worcester MA | Dwight Ernest | Aviation Marketplace | 0 | April 6th 04 03:59 PM |
MS FS 2004 ---minimum equipment for IFR | Gerald Sylvester | Simulators | 14 | December 22nd 03 10:05 PM |
