On Fri, 28 Mar 2008 01:54:54 -0400, Roger
wrote: Snip for brevity They are long enough that it's more difficult to point them where you don't want to, they are very effective and the shot stops in the first or second wall instead of 3, 4, or 5 houses down the street.. Besides Some one remarked about this statement and I can't find it now. However I stand by it as phrased. Except for concrete and/or brick veneer, the walls of a house consist of a 3/8 or 1/2 piece of plaster board over studs on either 16" or larger centers plus insulation. The outside wall is a layer of insulation you could easily stick your fist through covered by either wood or vinyl siding. Unless you hit one of the studs, a 9mm which is noted for it's penetrating abilities can go through a lot of material like that. Like others I'd suggest the frangible hollow points. which *might* make it to the first neighbors house. As to the1" at 20 yards, I've shot a lot of handguns that couldn't do that from a rest. As for me, guns aside, I've never been able to do that with any hand gun. between the tremendous noise and fantastic muzzle flash inside at night should be good enough to discourage all but the most determined. My own feelings are that If they are that determined you are still better off with the 12Ga and probably in very deep doggie do. Dan Mc Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Mar 29, 12:05 am, Roger wrote:
Some one remarked about this statement and I can't find it now. However I stand by it as phrased. Except for concrete and/or brick veneer, the walls of a house consist of a 3/8 or 1/2 piece of plaster board over studs on either 16" or larger centers plus insulation. The outside wall is a layer of insulation you could easily stick your fist through covered by either wood or vinyl siding. Unless you hit one of the studs, a 9mm which is noted for it's penetrating abilities can go through a lot of material like that. You must have some mighty big heating bills. Most newer balloon frame houses also have a layer of 1/2" to 3/4" OD particle board on the exterior walls upon which to hang the siding. Older houses (1960) used even more dense material. And the only thing that makes a 9 mm round "penetrating" is a Full Metal Jacket (FMJ). Use a modern hollow point (such as a Speer Gold Dot) and I doubt a 9 mm will make it through an interior wall without losing significant energy. I think you have fallen prey to anti-gun rantings. The fact is that the impact of a 9mm bullet --at muzzle velocity -- is equal to a *one pound* weight dropped from a height of 5.96 feet (achieving a velocity of 19.6 fps) or a ten pound weight dropped from a height of 0.72 inches (yes, that's 3/4 of an inch!) Sorry, but that's not a whole lot of power. As I said before -- a handgun is what you use to fight your way to your long gun. Dan Mc |
![]() "Dan" wrote in message ... On Mar 29, 12:05 am, Roger wrote: And the only thing that makes a 9 mm round "penetrating" is a Full Metal Jacket (FMJ). Use a modern hollow point (such as a Speer Gold Dot) and I doubt a 9 mm will make it through an interior wall without losing significant energy. An interior wall? Two layers of sheetrock? You need some hands on experience. I think you have fallen prey to anti-gun rantings. The fact is that the impact of a 9mm bullet --at muzzle velocity -- is equal to a *one pound* weight dropped from a height of 5.96 feet (achieving a velocity of 19.6 fps) or a ten pound weight dropped from a height of 0.72 inches (yes, that's 3/4 of an inch!) Sorry, but that's not a whole lot of power. As I said before -- a handgun is what you use to fight your way to your long gun. You don't know much about gun fights either, do ya? |
On Mar 29, 9:11 am, "Maxwell" luv^2^fly^99@^cox.^net wrote:
You don't know much about gun fights either, do ya? I haven't read as many Soldier of Fortune articles as you, apparently. |
![]() "Dan" wrote in message ... On Mar 29, 9:11 am, "Maxwell" luv^2^fly^99@^cox.^net wrote: You don't know much about gun fights either, do ya? I haven't read as many Soldier of Fortune articles as you, apparently. No, it's because all your training is military, not civilian or law enforcement. |
On 2008-03-29, Dan wrote:
The fact is that the impact of a 9mm bullet --at muzzle velocity -- is equal to a *one pound* weight dropped from a height of 5.96 feet (achieving a velocity of 19.6 fps) or a ten pound weight dropped from a height of 0.72 inches (yes, that's 3/4 of an inch!) What size of 1lb weight? It depends on the density of that 1 lb weight. If that weight was one micron cubed, it would probably go all the way to the centre of the earth. But 1lb of duck feathers wouldn't even hurt you at that velocity. A 1lb weight travelling at 19.6 fps, or in proper units, a 0.455 kilogram weight travelling at 6 metres per second has twenty times the kinetic energy of a .45 round (around 8 kilojoules, versus the .45's kinetic energy of about 0.5 kilojoules). -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
Static Discharge | gman | Piloting | 12 | March 24th 07 07:56 PM |
IFR static discharge | [email protected] | Home Built | 0 | April 2nd 06 08:06 PM |
The Vanishing Honorable Discharge | Otis Willie | Naval Aviation | 0 | October 29th 04 02:58 AM |
