David Lesher wrote:
Err, that field has an inductance of something on the order of 1H. Opening the excitation to it will do what, in the short term? Crowbarring that field to ground & clearing the 5-10 amp field breaker sounds like a good idea to me, given the price of avionics in a aircraft, and the proprensity for people/Murphy to do bad things.... [I've seen car owners yank the battery cable off while the alternator is going full tilt; "The battery only starts the car; the alternator runs it..." The result was a 65V+ "load dump" hundreds of ms long into the car...fried computers, dead stereos, you name it.] I dont have an internal schematic of the LR3C to know exactly what the crowbar does. Two possibilities: One is that the crowbar is upstream of the regulator so it just blows the Field Breaker, effectively just removing power from the regulator/field, leaving whatever current is already flowing in the field inductance to dissipate itself in its own coil resistance. There is almost certainly a catch (snubber) diode across the field winding oriented such that the field current decays with a time constant of RL, where R is the coil resistance, and L is the coil inductance. Two is that the crowbar is downstream of the regulator (directly across the field winding). Throwing a dead short across the coil does not change the time constant mentioned above. The current will still continue to flow with a time constant of RL. The only way to "shut off" the current faster is to instantaneously reverse the voltage applied to the field winding, which a simple crowbar does not do. Neither method (unless the LR3C is a lot more complicated than I think it is) prevents a "load dump" as David Lesher describes it! This is why I think it is a poor design. It is no better than a more conventional OVP module such as used in Cessnas and Pipers which simply breaks the connection between the Field Breaker and the input to the regulator. Actually, I have been thinking about Steve's problem some more, and the transient which is tripping the crowbar could well be coming from a "load dump lite". He mentioned that his hydraulic pump is his biggest single load, ~35A. If his other loads are about 20A, then with pump running, the alternator is cranking out close to 55A. At the instant the hydraulic pump turns off, the field current is like 2A. Due to the high inductance of the field winding, it takes about a 1/4 second for the field current to decay back down to the less than the 1A it takes to produce an alternator output of 20A, during which the bus voltage spikes up, held in check only by the impedance of the battery. This could well be the event that triggers the OVP crowbar! I have seen similar OVP triggering in a Cessna 210, where the hydraulic gear pump motor cycles spontaneously as the pressure in the system leaks down. I called B&C today to ask about this, and the only suggestion was to connect pin 3 (sense input) of the LR3C as close to the battery as possible. In other words, the battery is the spike filter of last resort, so if there is a lot of wire (resistance) between pin 3 and the battery, then the impedance along the wire (and in the master relay) could allow pin 3 to see a higher voltage during the transient. B&C does not make a 28V ACU without OVP. Pin 3 on the LR3C is used as the sense input for both the OVP circuit and the regulator. B&C's owner could not tell me what the effective input resistance looking into Pin 3 is. If it were high enough, you could put a series R, shunt C filter in this wire to prevent the OVP part of the circuit from triggering when it shouldn't. However, this could also effect the control loop dynamics of the voltage regulator. I would try 100 Ohms in series with Pin 3 and 1000 uF (+ end to pin3 and - end to pin 7), time constant of 0.1 sec. You might have to tweak the voltage setting after adding the filter. The other possibility is to open the box, and put an appropriate filter between pin 3 and the OVP circuit such that it doesn't effect what the VR sees. |
MikeMl writes:
[I've seen car owners yank the battery cable off while the alternator is going full tilt; "The battery only starts the car; the alternator runs it..." The result was a 65V+ "load dump" hundreds of ms long into the car...fried computers, dead stereos, you name it.] I dont have an internal schematic of the LR3C to know exactly what the crowbar does. Two possibilities: One is that the crowbar is upstream of the regulator so it just blows the Field Breaker, effectively just removing power from the regulator/field, leaving whatever current is already flowing in the field inductance to dissipate itself in its own coil resistance. There is almost certainly a catch (snubber) diode across the field winding oriented such that the field current decays with a time constant of RL, where R is the coil resistance, and L is the coil inductance. I'd hope.. but is there one?? Two is that the crowbar is downstream of the regulator (directly across the field winding). Doesn't this assume the regulator is high-side; with the bottom of the field grounded? I thought the consensus was they were low-side, al-la GM; i.e. the top end of the field gets fed with +13V from the aux diodes or battery; and the regulator is in the leg to ground. Neither method (unless the LR3C is a lot more complicated than I think it is) prevents a "load dump" as David Lesher describes it! This is why I think it is a poor design. It is no better than a more conventional OVP module such as used in Cessnas and Pipers which simply breaks the connection between the Field Breaker and the input to the regulator. The issue there is opening that will need a fast, high voltage device that you can turn off. The SCR crowbar gets turned on to protect, an easier task. The issue with load dumps is not just the spike peak voltage; it's how long they last...i.e. total energy. The no-battery stunt was so harmful because the Xl of the field ensured it could not halt alternator quickly. So it wasn't a few ms of spike, it was many hundreds of ms worth... Actually, I have been thinking about Steve's problem some more, and the transient which is tripping the crowbar could well be coming from a "load dump lite". I don't recall the OP's remarks; did he indicate the pump cycling was tripping the breaker? Or was it an unknown? I agree the pump cycling could be an issue; your savior is often the low impedance of the battery eating those spikes. If it's not, the spikes may have gotten bigger, or the Xc of the battery lower... One spike solution is large MOV's across the spike creator. The gotcha there is: MOV's actually are sacrificial, as small spikes erode them over time; large ones will cause them to explode... [If you ever shake a "surge protected outlet strip" and it rattles; that's the ex-MOV inside...] I called B&C today to ask about this, and the only suggestion was to connect pin 3 (sense input) of the LR3C as close to the battery as possible. In other words, the battery is the spike filter of last resort, so if there is a lot of wire (resistance) between pin 3 and the battery, then the impedance along the wire (and in the master relay) could allow pin 3 to see a higher voltage during the transient. The other reason to do so is because the regulator is there to protect & serve the battery. You don't care all that much about the bus being a half volt too high or low; you DO care about the battery being that, and the bus does have drop. So you want to sense near/at the battery. But that brings a dilemma. You must have the sense line draw some current. Why? So the regulator is sure its sense line has not become disconnected from the battery. {If it does come loose, the regulator says "0 volts! More power to the field, Scotty" to compensate, and the smell of burnt silicon soon fills the area. There were some early transistorized auto regulators that did just that; long gone I hope!} But then, even with but a few mils of draw, if it does that for 2 months in the hangar....your battery is dead. So it must be switched, and that.... The other possibility is to open the box, and put an appropriate filter between pin 3 and the OVP circuit such that it doesn't effect what the VR sees. I wonder if an appropriate ferrite toroid on the sense lead could stop the noise spikes from tripping the OVP without degrading regulation. I can't recall what such toroids look like [i.e SPICE] when saturated with DC as it would be... |
David Lesher wrote:
MikeMl writes: ...There is almost certainly a catch (snubber) diode across the field winding oriented such that the field current decays with a time constant of RL, where R is the coil resistance, and L is the coil inductance. I'd hope.. but is there one?? Every transistorized regulator that I have ever looked inside of has had a snubber diode (inside the regulator) connected across the field winding. Both type B high-side and type A low-side regulators. Two is that the crowbar is downstream of the regulator (directly across the field winding). Doesn't this assume the regulator is high-side; with the bottom of the field grounded? I thought the consensus was they were low-side, al-la GM; i.e. the top end of the field gets fed with +13V from the aux diodes or battery; and the regulator is in the leg to ground. According to B&C's website, the LR3C is a high-side, grounded-field type of regulator. Neither method (unless the LR3C is a lot more complicated than I think it is) prevents a "load dump" as David Lesher describes it! This is why I think it is a poor design. It is no better than a more conventional OVP module such as used in Cessnas and Pipers which simply breaks the connection between the Field Breaker and the input to the regulator. The issue there is opening that will need a fast, high voltage device that you can turn off. The SCR crowbar gets turned on to protect, an easier task. Without a snubber diode, the open-circuited voltage across the field winding can spike to thousands of volts. You might get the field current to cease faster, but you will be replacing lots of regulator transistors. The issue with load dumps is not just the spike peak voltage; it's how long they last...i.e. total energy. The no-battery stunt was so harmful because the Xl of the field ensured it could not halt alternator quickly. So it wasn't a few ms of spike, it was many hundreds of ms worth... My measurements indicate that it takes about 250msec for the field current to decay during a load dump event. Actually, I have been thinking about Steve's problem some more, and the transient which is tripping the crowbar could well be coming from a "load dump lite". I don't recall the OP's remarks; did he indicate the pump cycling was tripping the breaker? Or was it an unknown? I agree the pump cycling could be an issue; your savior is often the low impedance of the battery eating those spikes. If it's not, the spikes may have gotten bigger, or the Xc of the battery lower... One spike solution is large MOV's across the spike creator. The gotcha there is: MOV's actually are sacrificial, as small spikes erode them over time; large ones will cause them to explode... [If you ever shake a "surge protected outlet strip" and it rattles; that's the ex-MOV inside...] I called B&C today to ask about this, and the only suggestion was to connect pin 3 (sense input) of the LR3C as close to the battery as possible. In other words, the battery is the spike filter of last resort, so if there is a lot of wire (resistance) between pin 3 and the battery, then the impedance along the wire (and in the master relay) could allow pin 3 to see a higher voltage during the transient. The other reason to do so is because the regulator is there to protect & serve the battery. You don't care all that much about the bus being a half volt too high or low; you DO care about the battery being that, and the bus does have drop. So you want to sense near/at the battery. But that brings a dilemma. You must have the sense line draw some current. Why? So the regulator is sure its sense line has not become disconnected from the battery. {If it does come loose, the regulator says "0 volts! More power to the field, Scotty" to compensate, and the smell of burnt silicon soon fills the area. There were some early transistorized auto regulators that did just that; long gone I hope!} But then, even with but a few mils of draw, if it does that for 2 months in the hangar....your battery is dead. So it must be switched, and that.... The other possibility is to open the box, and put an appropriate filter between pin 3 and the OVP circuit such that it doesn't effect what the VR sees. I wonder if an appropriate ferrite toroid on the sense lead could stop the noise spikes from tripping the OVP without degrading regulation. I can't recall what such toroids look like [i.e SPICE] when saturated with DC as it would be... I thought about an external L-C filter, but that could screw-up the voltage regulator's control loop dynamics. The RC filter seems safer. |
Noise Problem. Both Comms Breaking Squelch | Lancair IV-P Flyer | Owning | 26 | April 3rd 08 09:57 PM |
Tough noise problem in Arrow radios | Ray Andraka | Owning | 7 | February 18th 08 08:44 PM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Instrument Flight Rules | 15 | January 13th 07 12:06 AM |
Static/Squelch Noise in Radio | Kensandyeggo | Home Built | 2 | April 13th 06 09:00 PM |
Radio "Squelch-type" Noise | Kensandyeggo | Owning | 7 | April 12th 06 07:20 PM |
