Fiberglass cloth weight vs 'finished' weight
Old April 5th 08, 01:03 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
Default Fiberglass cloth weight vs 'finished' weight
On Mar 21, 11:05 am, wright1902glider
On Mar 20, 12:12 pm, Fred the Red Shirt
I conducted a few interesting (and historical) experiments using 2.3
oz cotton a few years ago. In one of Wilbur Wright's 1899 letters to
Octave Chanute, he asks about several things including a source for
spruce and the type of dope used on Chanute's gliders (1896-97)
stating that "hitherto we have used shellac".
Fascinating. I have wondered if shellac would be good for both
bonding and sealing the fabric.
Why not?
Good question! Here's what I found:
Assuming a 3-pound cut, I used 7 coats of orange shellac to fill the
weave (might be a little less for them since their fabric was about
1.8 oz.) That roughly trippled the weight of the fabric alone. By my
rough calculations, this would have equated to an additional 8 pounds
for the 1902 glider (317 sq, ft total surface). Considering the lift
limitations of their technology and the ultra-slow launch speeds, the
gains from reduced porosity (sp?) did not equal the loss from the [DSC]
added weight.
That works out to about 4.4 oz/square yd paint, plus the 1.8 oz
fabric
for a total of about 6 2 oz/square yd.
I'll assume that typical painted cloth finishes are no heavier, else
shellac
would be popular.
FF
Old April 5th 08, 02:12 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
I'd guess it would work ok (as per below) but ONLY on fabrics that
have a nap. That rules out dacron in favor of cotton. (with all
that that implies as well)
Recall Steve Wittman's accident - doped alone won't hold dacron
as a structural attachment.
Why not?
added weight.
fabric
shellac
would be popular.
I'm not completely sure that assumption would be valid.
Durability, UV resistance, chemical compatability, cost, longevety...
All these may have more impact than just weight alone...
Richard
(remove the X to email)
Now just why the HELL do I have to press 1 for English?
John Wayne
Old April 5th 08, 04:24 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
Why not?
added weight.
fabric
shellac
would be popular.
Good quality dewaxed shellac has good durability, is impervious
to petroleum based solvents, relatively cheap, and while it may
not last as long as some others, it can be refreshed just by
wiping it down with fresh alcohol.
I'd only use it on a small patch somewhere like on the
fuselage for a long time before doing a while plane with
it though.
FF
Max weight of K21 t-tree Soaring 1 February 3rd 07 10:25 AM
Weight of Ice gwengler Instrument Flight Rules 13 November 29th 06 04:19 AM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Weight LJ & Nancy Blodgett Home Built 23 September 27th 04 06:19 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
