On Sat, 12 Apr 2008 22:22:43 +0800, Stealth Pilot
wrote: On Fri, 11 Apr 2008 19:45:50 -0700, Road Dog wrote: I took my Piper Warrior in for its annual and the mechanic said that the compass card was missing and that he'd have to swing the plane to generate a new one. After swinging it, he claimed that he couldn't get the E-W deviation within the minimum. So he suggested we try "mu" shield (or something) to block the source of magnetism which he claims is coming from one of the instruments. (He says the compass works fine outside the plane.) Note: The instruments are all original, stock. Nothing has been changed (except a radio was added which he says is not the source.) The mu shield fails too. He says the next thing to try is to move the compass up to between the visors. He says he has spent 3 hours on this so far. I'm beginning to wonder, shouldn't a mechanic be able calibrate a compass in a stock Piper after 3 hours ? Is he incompetent ? Padding the bill ? Or does this really take this long ? He has inspected and fixed everything else. Do you think its reasonable at this time to ask him to sign off everything else, and take the plane somewhere else where, presumably, they know how to calibrate a compass ? the problem doesnt seem to be the compass but some stray magnetism in the aircraft. swinging a compass takes about 15 minutes. Swinging a compass in 15 minutes may be possible if no corrections are needed but to create a new card properly requires 8 points instead of just 4. chasing stray magnetism can take up a lot of time. Unless you have other reasons to believe that your mechanic is incompetent or trying to screw you then I'd be inclinded to trust him. |
On Sat, 12 Apr 2008 22:15:41 -0400, Jay Somerset
wrote: On Sat, 12 Apr 2008 16:11:59 GMT, (Drew Swinging a compass in 15 minutes may be possible if no corrections are needed but to create a new card properly requires 8 points instead of just 4. chasing stray magnetism can take up a lot of time. Unless you have other reasons to believe that your mechanic is incompetent or trying to screw you then I'd be inclinded to trust him. If you look at a deviation card, I think you'll find it takes 12 points -- every 30 degrees, not every 45 degrees. -- Jay (remove dashes for legal email address) You're right Jay I was thinking 8 extra but that's obviously not what I wrote. |
On Wed, 16 Apr 2008 05:19:27 +0000 (UTC),
(Alan) wrote: In article (Drew Dalgleish) writes: My home airport has a compass rose and I use that. Taxiing aroud and getting lined up on each heading takes me quite a bit longer than that. Having a helper would speed things I'm sure but if we consider man hours since the OP was about mechanics time then double your 15minutes. It is easier to shut down and just turn the plane from heading to heading manually. I was going to ask how do you know if it's an accurate land compass but it occurs to me that a GPS would do the job and then you could do it by yourself . How? A GPS knows where it is, not which way it is facing. Alan Do it while flying. The GPS know which way it's going. |
On Thu, 17 Apr 2008 02:03:18 GMT, (Drew
Dalgleish) wrote: On Wed, 16 Apr 2008 05:19:27 +0000 (UTC), (Alan) wrote: In article (Drew Dalgleish) writes: My home airport has a compass rose and I use that. Taxiing aroud and getting lined up on each heading takes me quite a bit longer than that. Having a helper would speed things I'm sure but if we consider man hours since the OP was about mechanics time then double your 15minutes. It is easier to shut down and just turn the plane from heading to heading manually. I was going to ask how do you know if it's an accurate land compass but it occurs to me that a GPS would do the job and then you could do it by yourself . How? A GPS knows where it is, not which way it is facing. Alan Do it while flying. The GPS know which way it's going. You really don't seem to understand -- heading and track are two different things. They are only aligned if you are flying directly into, or away from, the wind. So your GPS is pretty well useless in flight for aligning a compass, as you can never tell precisely the wind direction aloft. Certainly not within the +/- 3 degrees that you should be trying to calibrate against. -- Jay (remove dashes for legal email address) |
On Apr 17, 9:15*am, Jay Somerset wrote:
On Thu, 17 Apr 2008 02:03:18 GMT, (Drew Dalgleish) wrote: On Wed, 16 Apr 2008 05:19:27 +0000 (UTC), (Alan) wrote: In article (Drew Dalgleish) writes: My home airport has a compass rose and I use that. Taxiing aroud and getting lined up on each heading takes me quite a bit longer than that. Having a helper would speed things I'm sure but if we consider man hours since the OP was about mechanics time then double your 15minutes. *It is easier to shut down and just turn the plane from heading to heading manually. I was going to ask how do you know if it's an accurate land compass but it occurs to me that a GPS would do the job and then you could do it by yourself . *How? *A GPS knows where it is, not which way it is facing. * * * *Alan Do it while flying. The GPS know which way it's going. You really don't seem to understand -- heading and track are two different things. *They are only aligned if you are flying directly into, or away from, the wind. So your GPS is pretty well useless in flight for aligning a compass, as you can never tell precisely the wind direction aloft. *Certainly not within the +/- 3 degrees that you should be trying to calibrate against. -- Jay (remove dashes for legal email address)- Hide quoted text - - Show quoted text - Someone explained it pretty clearly earlier... use the GPS on the ground. Taxi slowly to get your heading/track where you want it then stop slowly and smoothly. Steve KDMW |
KAP 140 trouble | Dan Luke | Owning | 27 | July 12th 07 07:13 PM |
Syrian MiG-21 in trouble | Dave Kearton | Aviation Photos | 9 | March 3rd 07 11:20 PM |
Tie Down Trouble | Dylan Smith | Piloting | 16 | May 20th 06 09:47 PM |
compass turns with high mounted compass (Cessna 152) | Ray | Instrument Flight Rules | 22 | April 7th 05 07:39 AM |
engine trouble | mindenpilot | Owning | 16 | February 10th 05 02:17 AM |
