WingFlaps wrote in
: On Apr 18, 11:04*am, Bertie the Bunyip wrote: Stefan wrote in news:c9458$4807bcae$54487328$455 1 @news.hispeed.ch: WingFlaps schrieb: Perhap we are at crossed purposes but an ARFOR does not refer to an airfield -that's a METAR and not all fields issue them. So in this case how can QNH give field elevation unless it's an ISA day? Again: QNH gives *by definition* the field elevation. Only at the airport ref point, so, no, it doesn't. He'll get it in the end... high to low look out below! I'll guess he's not flown Xcountry to non ATIS fields? I doubt he flies at all. Bertie |
Bertie the Bunyip schrieb:
Again: QNH gives *by definition* the field elevation. Only at the airport ref point, so, no, it doesn't. Fascinating: You, who *never* ever have trimmed a post before you answered, are doing this for the first time! A miracle? A convert? No, a closer look reveals your reason: The untrimmed text was Again: QNH gives *by definition* the field elevation. If an ARFOR gives you a QNH, then it is related to one well defined spot on the surface. Which is exactly what you wrote in your answer. So without trimming, you couldn't have written "no". You're such an asshole. |
Stefan wrote:
Bertie the Bunyip schrieb: Again: QNH gives *by definition* the field elevation. Only at the airport ref point, so, no, it doesn't. Fascinating: You, who *never* ever have trimmed a post before you answered, are doing this for the first time! A miracle? A convert? No, a closer look reveals your reason: The untrimmed text was Again: QNH gives *by definition* the field elevation. If an ARFOR gives you a QNH, then it is related to one well defined spot on the surface. Which is exactly what you wrote in your answer. So without trimming, you couldn't have written "no". You're such an asshole. snicker |
Stefan wrote in news:ac07e$4808485c$54487328
: Bertie the Bunyip schrieb: Again: QNH gives *by definition* the field elevation. Only at the airport ref point, so, no, it doesn't. Fascinating: You, who *never* ever have trimmed a post before you answered, are doing this for the first time! A miracle? A convert? No, a closer look reveals your reason: The untrimmed text was Again: QNH gives *by definition* the field elevation. If an ARFOR gives you a QNH, then it is related to one well defined spot on the surface. Which is exactly what you wrote in your answer. So without trimming, you couldn't have written "no". You're such an asshole. nice try. You wuz wrong, cheese nazi. Bertie |
On Apr 18, 9:10*am, Stefan wrote:
WingFlaps schrieb: Perhap we are at crossed purposes but an ARFOR does not refer to an airfield -that's a METAR and not all fields issue them. So in this case how can QNH give field elevation unless it's an ISA day? Again: QNH gives *by definition* the field elevation. If an ARFOR gives you a QNH, then it is related to one well defined spot on the surface. BINGO! That's right, setting QNH on an altimeter DOES NOT does give field elevation UNLESS it's issued for that field :-) Cheers |
WingFlaps schrieb:
BINGO! That's right, setting QNH on an altimeter DOES NOT does give field elevation UNLESS it's issued for that field :-) Which has been pretty obvious, hasn't it? But I forgot that this is Usenet. |
On Apr 18, 6:56*pm, Stefan wrote:
WingFlaps schrieb: BINGO! That's right, setting QNH on an altimeter DOES NOT does give field elevation UNLESS it's issued for that field :-) Which has been pretty obvious, hasn't it? But I forgot that this is Usenet.. Nope it's not Usenet, it comes back to correcting the erroneous idea that setting QNH on an altimeter makes it faithfully report altitude. Cheers |
Stefan wrote in
: WingFlaps schrieb: BINGO! That's right, setting QNH on an altimeter DOES NOT does give field elevation UNLESS it's issued for that field :-) Which has been pretty obvious, hasn't it? But I forgot that this is Usenet. Oowww! Backpedaling and obfuscating! How predictable. Bertie |
Looking for TSO Altimeter | Rob Turk | Home Built | 0 | June 9th 07 03:52 PM |
Altimeter off | kevmor | Instrument Flight Rules | 11 | March 26th 07 12:11 PM |
Altimeter discrepancy | Gene Whitt | Instrument Flight Rules | 6 | August 1st 05 07:11 PM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Altimeter Disassembly | Dick | Home Built | 3 | April 2nd 05 01:27 PM |
