Thanks Udo, that's where I was heading with wing tips to simulate
flight loads, I was just trying to find out if this is normal for the type. Not sure yet how to apply bending loads to a single wing in order to check if the problem is specific to one side only, but certainly worth a try. Cheers Paul Udo wrote: I can not directly talk about the 55. I have a 27 which had a sticky problem. I simply isolated, (disconnect the links from the stick) Fortunate, I did not have to go further, as I discovered that the 2 bearings, that control the pitch were kaput. In any case the above procedure should apply for isolating any sort of excessive friction or bad bearings. You did not say if it was in pitch or lateral control. If lateral control is an issue you should have friends lift the wingtips and operate the stick under bending load while on the ground. Udo Hi I have recently acquired SZD-55. �The glider was manufactured in 1996 and has some 450 hrs. �As far as I can tell the glider was maintained very well by German workshop. �Whilst I was aware that the 55 has quite a heavy stick, I have only flown one other, this one seems to require quite a force to move the stick whilst in flight. �The friction force on the ground is negligible. Whilst I found the glider great to fly, responsive etc., the force required to move the stick becomes tiring after a while. �I also find that I tend to "overshoot" small corrections, static friction requiring more force to overcome compared to sliding friction. �Has anyone had similar experience and if so how could it be overcome. Also I have noticed that when the stick is at dead centre, both ailerons are deflected down by about 3mm (1/8"). Any help appreciated. cheers Paul |
Excessive valve clearance cause low power? | [email protected] | Owning | 16 | October 19th 07 09:11 PM |
Runway Friction Index | Icebound | Piloting | 15 | April 2nd 06 03:07 AM |
Shakedown: Friction Lock for Old 172 Mixture Control: $60 | jls | Home Built | 2 | January 30th 04 01:05 AM |
Throttle friction lock slipping - How do I stop this? | Ron | Home Built | 2 | January 24th 04 12:55 AM |
Shakespeare Throttle Friction Lock | Larry Smith | Home Built | 3 | November 8th 03 03:01 PM |
