On 22 Apr, 14:13, "kirk.stant" wrote:
Buy the biggest you can fit! Powersonic has a 9 AH in same format as 7.2 Then add more batteries, they are cheap, lost instruments are dangerous, lost OLC logs are maddening! From experience.... now running 3 batteries..... saves me adding water ballast! ;-) Bob AMEN! My solution was to split the cockpit into two electrical busses, each with it's own 9AH battery. Either side can fail and I have enough "stuff" to get home (or finish a race...). Can also gang the busses so either battery can power all the cockpit. I have 3 batteries, one is always on the charger, and rotate the ones from the flight every evening - so I always have 2 fully charged batteries every flight. No special connectors on the batteries, so any standard size 7 - 9 AH "brick" with spade connectors will fit, if necessary. It's worked so far (8 years and counting...). I see there are some new technology batteries coming on the market for gliders (in S&G?) - maybe we are about to move on from our beloved lead bricks! Kirk 66 I replaced my lead acid 7 ah brick with a NiMh pack made up by a supplier. The result is a pack that fits into the same battery holder slot, is 30% lower in height, 50% lighter, runs at 14v nominal and has a 9 Ah capacity. It was so succesfull that I replaced the second 15 ah battery used to raise and lower the turbo with a similar pack but of only 12ah but saving 7kg. One other advantage is that they use a purpose built microprocessor controlled charger that ensures they are fully charged and ready to go even when left permanently connected. |
On Apr 23, 1:56 am, nimbusgb wrote:
On 22 Apr, 14:13, "kirk.stant" wrote: Buy the biggest you can fit! Powersonic has a 9 AH in same format as 7.2 Then add more batteries, they are cheap, lost instruments are dangerous, lost OLC logs are maddening! From experience.... now running 3 batteries..... saves me adding water ballast! ;-) Bob AMEN! My solution was to split the cockpit into two electrical busses, each with it's own 9AH battery. Either side can fail and I have enough "stuff" to get home (or finish a race...). Can also gang the busses so either battery can power all the cockpit. I have 3 batteries, one is always on the charger, and rotate the ones from the flight every evening - so I always have 2 fully charged batteries every flight. No special connectors on the batteries, so any standard size 7 - 9 AH "brick" with spade connectors will fit, if necessary. It's worked so far (8 years and counting...). I see there are some new technology batteries coming on the market for gliders (in S&G?) - maybe we are about to move on from our beloved lead bricks! Kirk 66 I replaced my lead acid 7 ah brick with a NiMh pack made up by a supplier. The result is a pack that fits into the same battery holder slot, is 30% lower in height, 50% lighter, runs at 14v nominal and has a 9 Ah capacity. It was so succesfull that I replaced the second 15 ah battery used to raise and lower the turbo with a similar pack but of only 12ah but saving 7kg. One other advantage is that they use a purpose built microprocessor controlled charger that ensures they are fully charged and ready to go even when left permanently connected. Same here, 10Ah NiMh battery dedicated to the transponder, two 5Ah packs for the instruments (one in the tail). Charger is putting out 2A and takes only about 2-4h after a normal day of flying to replenish the batteries. I built the packs myself from cells with tabs and paid only $80 for the large 10Ah pack, half of that for each of the small ones. No more lead-acid batteries! The weight savings mentioned by nimbusgb might be a bit aggressive, I'd say NiMh is about 60% lighter than the same lead-acid capacity battery. Herb |
On Apr 23, 9:11 am, Herb wrote:
On Apr 23, 1:56 am, nimbusgb wrote: On 22 Apr, 14:13, "kirk.stant" wrote: Buy the biggest you can fit! Powersonic has a 9 AH in same format as 7.2 Then add more batteries, they are cheap, lost instruments are dangerous, lost OLC logs are maddening! From experience.... now running 3 batteries..... saves me adding water ballast! ;-) Bob AMEN! My solution was to split the cockpit into two electrical busses, each with it's own 9AH battery. Either side can fail and I have enough "stuff" to get home (or finish a race...). Can also gang the busses so either battery can power all the cockpit. I have 3 batteries, one is always on the charger, and rotate the ones from the flight every evening - so I always have 2 fully charged batteries every flight. No special connectors on the batteries, so any standard size 7 - 9 AH "brick" with spade connectors will fit, if necessary. It's worked so far (8 years and counting...). I see there are some new technology batteries coming on the market for gliders (in S&G?) - maybe we are about to move on from our beloved lead bricks! Kirk 66 I replaced my lead acid 7 ah brick with a NiMh pack made up by a supplier. The result is a pack that fits into the same battery holder slot, is 30% lower in height, 50% lighter, runs at 14v nominal and has a 9 Ah capacity. It was so succesfull that I replaced the second 15 ah battery used to raise and lower the turbo with a similar pack but of only 12ah but saving 7kg. One other advantage is that they use a purpose built microprocessor controlled charger that ensures they are fully charged and ready to go even when left permanently connected. Same here, 10Ah NiMh battery dedicated to the transponder, two 5Ah packs for the instruments (one in the tail). Charger is putting out 2A and takes only about 2-4h after a normal day of flying to replenish the batteries. I built the packs myself from cells with tabs and paid only $80 for the large 10Ah pack, half of that for each of the small ones. No more lead-acid batteries! The weight savings mentioned by nimbusgb might be a bit aggressive, I'd say NiMh is about 60% lighter than the same lead-acid capacity battery. Herb I have four batteries and like lead for the extra weight. Higher wing loading is good out west! Mike |
I'd love to see some pictures of your NiMh creations.
Can you send to me or upload somewhere like http://www.flickr.com. This would also be a great how to article for Soaring. john at derosaweb.com Thanks |
On 24 Apr, 11:20, ContestID67 wrote:
I'd love to see some pictures of your NiMh creations. Can you send to me or upload somewhere likehttp://www.flickr.com. This would also be a great how to article for Soaring. john at derosaweb.com Thanks Just as a matter of interest ..... I am flying OPA's at the moment ( other peoples aeroplanes ) and have a portable setup with Colibri logger and Ipaq PDA all driven from a LiPo Electric R/C aircraft flight pack. A12v pack with 2200ma/hr capacity. The power to volume/weight ratio is great. The pack weighs about 100g and is about the size of 6 cigarettes! It drives the setup for about 6 hours with the pda on all the time. Ian |
On Apr 24, 9:58*am, nimbusgb wrote:
On 24 Apr, 11:20, ContestID67 wrote: I'd love to see some pictures of your NiMh creations. Can you send to me or upload somewhere likehttp://www.flickr.com. This would also be a great how to article for Soaring. john at derosaweb.com Thanks Just as a matter of interest ..... I am flying OPA's at the moment ( other peoples aeroplanes ) and have a portable setup with Colibri logger and Ipaq PDA all driven from a LiPo Electric R/C aircraft flight pack. A12v pack with 2200ma/hr capacity. The power to volume/weight ratio is great. The pack weighs about 100g and is about the size of 6 cigarettes! It drives the setup for about 6 hours with the pda on all the time. Ian I would never fly with LiPo on board. Let alone in someone elses ship. I have quite a few of them for my R/C aircraft and have seen them at their worst. Please be careful. |
On Apr 24, 12:30*pm, Marc Ramsey wrote:
wrote: On Apr 24, 9:58 am, nimbusgb wrote: I am flying OPA's at the moment ( other peoples aeroplanes ) and have a portable setup with Colibri logger and Ipaq PDA all driven from a LiPo Electric R/C aircraft flight pack. A12v pack with 2200ma/hr capacity. The power to volume/weight ratio is great. The pack weighs about 100g and is about the size of 6 cigarettes! It drives the setup for about 6 hours with the pda on all the time. Ian I would never fly with LiPo on board. Let alone in someone elses ship. I have quite a few of them for my R/C aircraft and have seen them at their worst. Please be careful. You don't fly with a cell phone or a PDA? Marc Not with lithium Polymer batteries. Lithium Ion, yes. Lithium Polymer, no. |
wrote: On Apr 24, 9:58 am, nimbusgb wrote: I am flying OPA's at the moment ( other peoples aeroplanes ) and have a portable setup with Colibri logger and Ipaq PDA all driven from a LiPo Electric R/C aircraft flight pack. A12v pack with 2200ma/hr capacity. The power to volume/weight ratio is great. The pack weighs about 100g and is about the size of 6 cigarettes! It drives the setup for about 6 hours with the pda on all the time. Ian I would never fly with LiPo on board. Let alone in someone elses ship. I have quite a few of them for my R/C aircraft and have seen them at their worst. Please be careful. You don't fly with a cell phone or a PDA? Marc Have you ever seen an R/C LiPo cell? No hard case. It is essentially a tin-foil-like bag of chemicals with a very high energy density. |
On 23 Apr, 16:11, Herb wrote:
On Apr 23, 1:56 am, nimbusgb wrote: On 22 Apr, 14:13, "kirk.stant" wrote: Buy the biggest you can fit! Powersonic has a 9 AH in same format as 7.2 Then add more batteries, they are cheap, lost instruments are dangerous, lost OLC logs are maddening! From experience.... now running 3 batteries..... saves me adding water ballast! ;-) Bob AMEN! My solution was to split the cockpit into two electrical busses, each with it's own 9AH battery. Either side can fail and I have enough "stuff" to get home (or finish a race...). Can also gang the busses so either battery can power all the cockpit. I have 3 batteries, one is always on the charger, and rotate the ones from the flight every evening - so I always have 2 fully charged batteries every flight. No special connectors on the batteries, so any standard size 7 - 9 AH "brick" with spade connectors will fit, if necessary. It's worked so far (8 years and counting...). I see there are some new technology batteries coming on the market for gliders (in S&G?) - maybe we are about to move on from our beloved lead bricks! Kirk 66 I replaced my lead acid 7 ah brick with a NiMh pack made up by a supplier. The result is a pack that fits into the same battery holder slot, is 30% lower in height, 50% lighter, runs at 14v nominal and has a 9 Ah capacity. It was so succesfull that I replaced the second 15 ah battery used to raise and lower the turbo with a similar pack but of only 12ah but saving 7kg. One other advantage is that they use a purpose built microprocessor controlled charger that ensures they are fully charged and ready to go even when left permanently connected. Same here, 10Ah NiMh battery dedicated to the transponder, two 5Ah packs for the instruments (one in the tail). Charger is putting out 2A and takes only about 2-4h after a normal day of flying to replenish the batteries. I built the packs myself from cells with tabs and paid only $80 for the large 10Ah pack, half of that for each of the small ones. No more lead-acid batteries! The weight savings mentioned by nimbusgb might be a bit aggressive, I'd say NiMh is about 60% lighter than the same lead-acid capacity battery. Herb Sorry not 7kg but 7lb lighter than the big 18Ah (?) pack.I agree about 60% of the weight of the lead acids. Ian |
Battery Connectors | Paul Remde | Soaring | 1 | September 15th 06 09:46 PM |
battery self-destruct | [email protected] | Owning | 13 | June 13th 06 11:04 PM |
Battery Source | Mike the Strike | Soaring | 81 | October 28th 05 12:46 AM |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
2-33 battery installation | Kurt | Soaring | 2 | January 27th 04 01:36 PM |
