Battery 6ah vs. more
Old April 24th 08, 04:07 PM posted to rec.aviation.soaring
Default Battery 6ah vs. more
On Apr 24, 9:58*am, nimbusgb wrote:
On 24 Apr, 11:20, ContestID67 wrote:
I'd love to see some pictures of your NiMh creations.
Can you send to me or upload somewhere likehttp://www.flickr.com.
This would also be a great how to article for Soaring.
john at derosaweb.com
Thanks
Just as a matter of interest .....
I am flying OPA's at the moment ( other peoples aeroplanes ) and have
a portable setup with Colibri logger and Ipaq PDA all driven from a
LiPo Electric R/C aircraft flight pack. A12v pack with 2200ma/hr
capacity. The power to volume/weight ratio is great. The pack weighs
about 100g and is about the size of 6 cigarettes! It drives the setup
for about 6 hours with the pda on all the time.
Ian
I would never fly with LiPo on board. Let alone in someone elses ship.
I have quite a few of them for my R/C aircraft and have seen them at
their worst. Please be careful.
Old April 24th 08, 06:59 PM posted to rec.aviation.soaring
Ian
You don't fly with a cell phone or a PDA?
Marc
Not with lithium Polymer batteries. Lithium Ion, yes. Lithium
Polymer, no.
Old April 24th 08, 07:17 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Ian
Marc
Polymer, no.
What makes you think the "lithium ion" cells used in PDAs, laptops, and
cellphones are any different than the "lithium polymer" cells used in
R/C aircraft? Have you ever looked at the cells inside a PDA, or inside
the plastic cases used for cellphone or laptop batteries? Nearly all
are lithium polymer these days (and the R/C suppliers get theirs from
the same factories, which is why they are relatively cheap), although
the laptop manufacturers, thanks to some rather public incidents, are
just starting to switch over to newer, somewhat less flammable, battery
chemistries...
Marc
Old April 24th 08, 08:52 PM posted to rec.aviation.soaring
Ian
Marc
Not with lithium Polymer batteries. Lithium Ion, yes. *Lithium
Polymer, no.
R/C aircraft? *Have you ever looked at the cells inside a PDA, or inside
the plastic cases used for cellphone or laptop batteries? *Nearly all
chemistries...
Marc- Hide quoted text -
- Show quoted text -
Sorry, didn't mean to start an argument. Maybe my caution regarding
flying with R/C (foil bag) LiPo batteries is a little over the top. I
can live with erring on the side of caution. To each his own.
Old April 24th 08, 09:51 PM posted to rec.aviation.soaring
SoaringXCellence
I'm not trying to get into an argument either, just making the point
that most of us already carry several foil bag lithium polymer batteries
in our gliders. *The original metal case lithium ion batteries haven't
been used in consumer products for years, mostly because we want
everything light (remember 8 lb laptops?).
R/C batteries have a high (explosive 8^) failure rate mostly due to the
various kinds of abuse they are subject to, incorrect charging,
continued use after being damaged in crashes, overly high discharge
rates, full short circuits, etc. *If someone knows what they are doing,
there shouldn't be a problem. *But, I agree, if you don't know, don't do
it. *I, for one, wouldn't want a pack large enough *to power a radio and
transponder in my glider...
Marc
I have done the RC thing for over 45 years. I've observed that as the
use of LiPo cells have progressed the rate of failure has decreased.
Inspite of that I would also either use a metal cased cells or a pack
in a metal box if I were to use them in an aviation application.
Istalled in the PDA or Cell phone they have some puncture protection
and that seems to be one of the major hazards to their use.
On the same idea; the A123systems cells are metal cased and at $110
for six (2.3 Ah) of them is a pretty good deal as far as lithium cells
go. I'm planning on getting several "Developer Kits" to assemble
several packs for the glider. Four cells, each a little larger than a
AA Alkaline, means that I can get a pretty good serial/parallel
battery setup and fit the individual battery packs into small
spaces.
The BIG handicap is the cost; to assemble 3 packs will cost $220 plus
assembly and wiring, for a 7.2AH pack.
Old April 24th 08, 07:04 PM posted to rec.aviation.soaring
Ian
Marc
Have you ever seen an R/C LiPo cell? No hard case. It is essentially
a tin-foil-like bag of chemicals with a very high energy density.
Battery Connectors Paul Remde Soaring 1 September 15th 06 09:46 PM
battery self-destruct [email protected] Owning 13 June 13th 06 11:04 PM
Battery Source Mike the Strike Soaring 81 October 28th 05 12:46 AM
Battery Chargers Stan Amyett Soaring 2 March 12th 04 05:27 AM
2-33 battery installation Kurt Soaring 2 January 27th 04 01:36 PM
