Feds Want to Equipe Gliders With Transponders and Radios
Old April 27th 08, 07:55 PM posted to rec.aviation.piloting,rec.aviation.soaring
Vaughn Simon
Default Feds Want to Equipe Gliders With Transponders and Radios
"Larry Dighera" wrote in message
1) Provides a framework of preplanned manuvers for aircraft to use to avoid
each other (but only if they both see each other, know the regulations, and
are
inclined to follow them).
Actually, that is true if only one pilot makes visual contact too.
Not so.
If the other plane does not see you, it can't be expected/trusted to behave
according to the ROW regulations, so you can't know what it is going to do.
There is usually little that you can do to get the other pilot's attention (you
have no horn in an aircraft). So it is up to the pilot that DOES see the other
to do whatever it takes to avoid a collision...regulations be dammed.
In that situation, I usually manuver in such a way that I never lose sight of
the other aircraft. If I happen to be driving a glider, my manuvering options
are limited to left, right, and down. I probably can't climb, and I certainly
can't outrun an oncoming airplane.
Vaughn
Old April 27th 08, 08:20 PM posted to rec.aviation.piloting,rec.aviation.soaring
Larry Dighera
On Sun, 27 Apr 2008 18:55:53 GMT, "Vaughn Simon"
wrote in
are
Not so.
So if you see a glider in you path while piloting a powered aircraft,
but its pilot doesn't see you, you don't give it the right of way?
Old April 27th 08, 08:47 PM posted to rec.aviation.piloting,rec.aviation.soaring
Vaughn Simon
wrote in
are
Not so.
I said no such thing. Kindly go back and read what I wrote.
Sorry, but I think you and I are done with this conversation.
Vaughn
Old April 27th 08, 09:06 PM posted to rec.aviation.piloting,rec.aviation.soaring
Michael Ash
In my opinion, right of way is essentially useless when flying.
There are three relevant situations:
- You are on a collision course with another aircraft. You have the ROW.
- You are on a collision course with another aircraft. He has the ROW.
- You are on a collision course with another aircraft. Neither has the
ROW.
In all three situations the only reasonable thing to is the same: maneuver
to avoid by any means necessary.
Thus your inference is essentially backwards. Not only should the power
plane get out of the way of the glider, but the glider should get out of
the way of the power plane.
Michael Ash
Rogue Amoeba Software
Old May 1st 08, 03:42 PM posted to rec.aviation.piloting,rec.aviation.soaring
Steven P. McNicoll[_2_]
So if you see a powered aircraft in you path while piloting a glider, but
its pilot doesn't see you, do you expect it to yield the right-of-way?
Old April 27th 08, 08:58 PM posted to rec.aviation.piloting,rec.aviation.soaring
WingFlaps
On Apr 28, 6:55*am, "Vaughn Simon"
are
* *Not so.
* *If the other plane does not see you, it can't be expected/trusted to behave
according to the ROW regulations, so you can't know what it is going to do..
have no horn in an aircraft). *So it is up to the pilot that DOES see the other
the other aircraft. *If I happen to be driving a glider, my manuvering options
are limited to left, right, and down. *I probably can't climb, and I certainly
To give way you must turn to the right. You can certainly dive fast
and turn as well if you really wan't to generate a big separation. But
remember he won't see you as easily if you go below him.. Radio calls?
Cheers
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Piloting 155 May 10th 08 02:45 PM
Gliders, transponders, and MOAs Greg Arnold Soaring 2 May 26th 06 05:13 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
Transponders and Radios - USA Ray Lovinggood Soaring 1 February 27th 04 06:10 PM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 2nd 03 11:27 PM
