control cable questions
Old May 8th 08, 12:45 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default control cable questions
thanks,would appreciate it. Are your cables 1/8"?
Old May 8th 08, 02:14 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Trimmed a little tight on that one but the threading looks like your are
talking to me so yes, they are 1/8".
Old May 8th 08, 02:27 PM posted to rec.aviation.homebuilt
Dick[_1_]
g. just the start of one of those days where I can't get anything right .
Here's probably a better reference.
I don't have my plans here at the office they are at the airport but I
THINK. It is an AN115-21 cable shackle. If someone else doesn't pop up with
the answer shortly I can find out for you.
Old May 8th 08, 05:10 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Dick, I just checked and surprisingly my memory was correct, it is
AN115-21 shackles.
There is a picture of this connection here.
http://peoamerica.net/N601WR/html/fuselage_1_180.html
Old May 8th 08, 06:21 PM posted to rec.aviation.homebuilt
Dick[_1_]
Thanks, good picture. My buddy is going to add brake lines from the Matco
units and a remote firewall mounted brake fluid reservoir.
"Gig 601Xl Builder" wrote in message
m...
with the answer shortly I can find out for you.
AN115-21 shackles.
Old May 8th 08, 08:06 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
I decided the guy in the right seat didn't need brakes because I didn't
want to go to the hassle of a dual set up. I am going to add a parking
brake though.
Old May 8th 08, 09:56 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default control cable questions now brakes
He also decided not to have right seat brakes but I was wondering what you
thought of the brake master reservoir on the firewall idea (so he doesn't
have to crawl inside and under the panel)?
Also what kind of parking brake are you thinking about?
Thanks
"Gig 601Xl Builder" I am going to add a parking brake though.
Old May 9th 08, 12:47 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
m...
brake though.
Were I to do it over again, I would delete the parking brake. I nine years,
I found little or no use for it. Wasted space and weight IMHO. I am glad I
put in brakes on both sides, though. When the day comes I need to sell it
(sob) I will want to be able to let the prospective buyer have brakes for
his pre-buy flights. When I bought my first Emeraude, there were no brakes
on the right and I was never able to get good taxi and landing practice. My
first flight on the left (after handing over the check) was very dicey as I
found I had inadequate room to operate the pedals on that side. The seller
had to take over in the middle of the takeoff 'cuz I was headed for the FBO.
For a dual setup, I built it with four master cylinders. I would instead use
two cylinders and link the toe brakes together mechanically.
Mrs. Murphy said, as she kissed the cow, "Each to his/her own liking".
Rich S.
control cable protection question Dick[_1_] Home Built 11 March 13th 08 11:31 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
