#11
I can believe there will be a problem if the pilot does not correctly keep
his speed up when he turns downwind, but if a plane was flying when it started the turn, and the same airspeed is maintained, there will not be a crash. -- Jim in NC However is it not true that perception of airspeed WITHOUT a indicator other than ones eye is very difficult when standing on the ground than it is at any other time??? Les |
![]() However is it not true that perception of airspeed WITHOUT a indicator other than ones eye is very difficult when standing on the ground than it is at any other time??? Yes, and that is what I was hinting at. Yet, if the pilot does not reduce throttle, or gain altitude during the turn, and makes the turn just like he always turns (probably true in most cases) then there would be no reason to be slowing down, no matter what he observed with the airspeed. It is a nice way to cover saying (or not to say) I screwed the pooch, to the uninformed! -- Jim in NC |
That is because the cause for each of the crashes was somewhat the same.
The Buff did not use regular ailerons, as you would normally think of them. The flexibility of the wing would twist when a normal aileron input was applied, and would actually give the opposite roll reaction that was expected. The aileron was acting like a boost tab, in sorts. The solution was to control roll by having a spoiler instead of an aileron, so that if you wanted to roll right, the right spoiler went up, that side lost some lift, and the aircraft rolls. It was also good to prevent adverse yaw. The only problem with that type of control roll, was that if a critical bank angle was exceeded, the roll was unrecoverable. Your were going to crash, period. The full sized crash was being piloted by a senior pilot who was known as a cowboy, and exceeded various flight parameters, frequently. Some crew would not fly with him. He pulled his steep bank trick one too many times, and did not get away with it. The RC model might have gotten too steep, in a normal flight pattern, but I think what happened was that the overcast sky messed up the pilot's orientation clues, and he banked steeper, rather that flattening it out. I've done it, and about anyone who flies RC has also done it, and gotten it back into control. With the model Buff, getting that steep put you into an unrecoverable area of the flight envelope. Boom, was the final result. -- Jim in NC Thanks Jim, for the explanation of the Buff's flight characteristics. I was well aware of the reputation of the pilot. There are numerous cases of the pilot in control killing their crews by doing what they shouldn't. I always kept that in mind when the pilots I flew with exceeded my comfort zone. Fly safe. Rob |
Last ever flying Jaguar not flying anymore.... - _07Oct19-36.jpg (0/1) | Martin J Hooper | Aviation Photos | 7 | January 15th 08 06:08 PM |
Last ever flying Jaguar not flying anymore.... - _07Oct19-36.jpg (1/1) | Martin J Hooper | Aviation Photos | 0 | January 7th 08 01:59 PM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | Aviation Marketplace | 9 | January 4th 04 02:24 AM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | General Aviation | 9 | January 4th 04 02:24 AM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
