On Jul 12, 3:44*am, cfinn wrote:
On Jul 12, 2:12*am, wrote: On Jul 11, 9:21*pm, Richard wrote: On Jul 11, 9:12*pm, wrote: I just received my HAiCOM HI-303III CF Card GPS and can not get WinPilot, running on my iPAQ 3950, to recognize it. I installed software on the iPAQ that shows me the gps is working and I can see my position. I've used a Garmin 12xl with cable hookups in the past with no problem. Does anyone have any suggestions to help out? Thanks, Ray Ray, The correct com port and baud rate needs to be set in WinPilot ADV. Richardwww.craggyaero.com That's what I thought Richard but I sure don't seem to be able to find where in WinPilot to set the correct com port and baud rate. I'm running the expansion sleeve and the gps is com port 6. Ray- Hide quoted text - - Show quoted text - To set the com port, touch the "menu" button at the top, touch "more" button until you see "com port" as one of the options, select the "6" radio button under "Com", touch the "OK" button at the the top. Most GPS systems use 4,800 baud. If you don't see a "com port" option on any of the menu pages, you'll need to edit a page and select it as a menu item. That should get you going. Charlie- Hide quoted text - - Show quoted text - There is no "com port" button under any of the menu pages. The only edit I see on the menu pages is at the bottom and it edits the hard button function on the bottom of my pda. How do I "edit a page"? I'm running WinPilot Adv Version 7.02. Thanks again, Ray |
edit I see on the menu pages is at the bottom and it edits the hard button function on the bottom of my pda. How do I "edit a page"? I'm running WinPilot Adv Version 7.02. Thanks again, Ray- Hide quoted text - - Show quoted text - If you touch the "Menu" button, you will seean "Edit" button at the bottom of each of the three menu pages. Touch the "edit" button and then touch any of the menu items. I drop down list will appear. Select "Com port" from the list. You'll then need to close the menu for the change to take place. Open the menu again and go to the page that you edited. You should now see "Com port" on the button you selected to edit. Select it and change your com port. After you have made the changes, you can edit the menu and return the button to its previous function, if you desire. Charlie |
On Jul 12, 12:53*pm, cfinn wrote:
There is no "com port" button under any of the menu pages. The only edit I see on the menu pages is at the bottom and it edits the hard button function on the bottom of my pda. How do I "edit a page"? I'm running WinPilot Adv Version 7.02. Thanks again, Ray- Hide quoted text - - Show quoted text - If you touch the "Menu" button, you will seean "Edit" button at the bottom of each of the three menu pages. Touch the "edit" button and then touch any of the menu items. I drop down list will appear. Select "Com port" from the list. You'll then need to close the menu for the change to take place. Open the menu again and go to the page that you edited. You should now see "Com port" on the button you selected to edit. Select it and change your com port. After you have made the changes, you can edit the menu and return the button to its previous function, if you desire. Charlie Ah....Success! I finally got the drop down menu to select "com port" and then I was able to select com port 6 and it works! Thanks to everyone for their help and to my friend Richard G. who told me about this forum yesterday. I'll keep looking at the subjects and hopefully will be able to help someone else. Thanks again, Ray |
Winpilot | NGC | Soaring | 3 | November 22nd 07 06:00 AM |
WinPilot | AK | Soaring | 1 | September 28th 07 04:41 AM |
Winpilot and OLC | P. Corbett | Soaring | 3 | March 26th 06 10:54 PM |
WinPilot and OLC | Doug LS4 | Soaring | 2 | December 15th 05 12:45 PM |
WinPilot Offers Free WinPilot XP for your Desktop Computer | Richard Pfiffner | Soaring | 0 | November 8th 03 04:44 PM |
