Gear position to rig
Old August 10th 08, 01:48 AM posted to rec.aviation.soaring
Default Gear position to rig
Reason for putting gear down before rigging: I've been doing it that
way for 35+ years and I figure if I change now, then one day I'll
forget and push the assembled glider out of the cradle without
dropping the gear.
Don't have a hydraulic jack. With my solo rigging device, the wheel is
several inches off the ground anyway. Also, when the fuselage is
recently waxed, it tends to slide aft occasionally during rigging.
Dropping the gear and lowering the cradle to where the wheel just
touches the ground helps mitigate that.
Chip Bearden
ASW 24 "JB"
USA
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
VFR position reporting Mxsmanic Piloting 154 November 26th 06 04:45 PM
Prop position Dan Luke Piloting 28 March 22nd 06 06:46 PM
Prop position Dan Luke Owning 28 March 22nd 06 06:46 PM
ATC says wrong position Greg Esres Instrument Flight Rules 28 April 30th 04 05:37 PM
