"Dakota" luv2^fly99@cox.^net wrote in
: "Bertie the Bunyip" wrote in message ... Robert Moore wrote in 5.205: Bertie the Bunyip wrote The next generation are eschewing bleed air driven pressurisation and going to seperate supercharger systems. A lot of older turboprops used this system as well as a small number of jets. The 787 will have this system. The B-707 had both Bleed Air and Turbochargers. We used the Turbochargers most of the time. An engine bleed line spun a turbine which then turned a fresh outside air compressor. Yeah, that was the jet exception I had noted. You were lucky you didn't have to breath the compresser section air in that thing! The JT8 was OK AFAIK There would have been some fumes, but the RB-211 is a complete piece of junk. The Brits never could build an oil tight engine.... Bertie Damn, I wish they would have let you design it. It would have been perfect, uh. Couldn't have done any worse... Bertie |
![]() "Bertie the Bunyip" wrote in message ... "Dakota" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... Robert Moore wrote in 5.205: Bertie the Bunyip wrote The next generation are eschewing bleed air driven pressurisation and going to seperate supercharger systems. A lot of older turboprops used this system as well as a small number of jets. The 787 will have this system. The B-707 had both Bleed Air and Turbochargers. We used the Turbochargers most of the time. An engine bleed line spun a turbine which then turned a fresh outside air compressor. Yeah, that was the jet exception I had noted. You were lucky you didn't have to breath the compresser section air in that thing! The JT8 was OK AFAIK There would have been some fumes, but the RB-211 is a complete piece of junk. The Brits never could build an oil tight engine.... Bertie Damn, I wish they would have let you design it. It would have been perfect, uh. Couldn't have done any worse... Bertie Yeah, lamers like you are usually of such an opinion. |
"DanO" luv2^fly99@cox.^net wrote in news:B15qk.21682$LF2.732
@newsfe09.iad: "Bertie the Bunyip" wrote in message ... "Dakota" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... Robert Moore wrote in 5.205: Bertie the Bunyip wrote The next generation are eschewing bleed air driven pressurisation and going to seperate supercharger systems. A lot of older turboprops used this system as well as a small number of jets. The 787 will have this system. The B-707 had both Bleed Air and Turbochargers. We used the Turbochargers most of the time. An engine bleed line spun a turbine which then turned a fresh outside air compressor. Yeah, that was the jet exception I had noted. You were lucky you didn't have to breath the compresser section air in that thing! The JT8 was OK AFAIK There would have been some fumes, but the RB-211 is a complete piece of junk. The Brits never could build an oil tight engine.... Bertie Damn, I wish they would have let you design it. It would have been perfect, uh. Couldn't have done any worse... Bertie Yeah, lamers like you are usually of such an opinion. Oh do tell us your take on labyrinth seals then, wannabe boi. Bertie |
![]() "Bertie the Bunyip" wrote in message .. . Bertie Yeah, lamers like you are usually of such an opinion. Oh do tell us your take on labyrinth seals then, wannabe boi. Bertie I'm not the one claiming to be the whiz kid lamer, you are. |
"DanO" luv2^fly99@cox.^net wrote in news:hq5qk.27504$1N1.20982
@newsfe07.iad: "Bertie the Bunyip" wrote in message .. . Bertie Yeah, lamers like you are usually of such an opinion. Oh do tell us your take on labyrinth seals then, wannabe boi. Bertie I'm not the one claiming to be the whiz kid lamer, you are. I made no claim. You gave me an accolade and I merely conceded that you were correct. Fjukktard. Bertie |
... "Dakota" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... Robert Moore wrote in 5.205: Bertie the Bunyip wrote The next generation are eschewing bleed air driven pressurisation and going to seperate supercharger systems. A lot of older turboprops used this system as well as a small number of jets. The 787 will have this system. The B-707 had both Bleed Air and Turbochargers. We used the Turbochargers most of the time. An engine bleed line spun a turbine which then turned a fresh outside air compressor. Yeah, that was the jet exception I had noted. You were lucky you didn't have to breath the compresser section air in that thing! The JT8 was OK AFAIK There would have been some fumes, but the RB-211 is a complete piece of junk. The Brits never could build an oil tight engine.... Bertie Damn, I wish they would have let you design it. It would have been perfect, uh. Couldn't have done any worse... Bertie From all that I heard, back when Eastern was flying L1011's, that is putting it politely. Peter |
"Peter Dohm" wrote in
: "Bertie the Bunyip" wrote in message ... "Dakota" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... Robert Moore wrote in 5.205: Bertie the Bunyip wrote The next generation are eschewing bleed air driven pressurisation and going to seperate supercharger systems. A lot of older turboprops used this system as well as a small number of jets. The 787 will have this system. The B-707 had both Bleed Air and Turbochargers. We used the Turbochargers most of the time. An engine bleed line spun a turbine which then turned a fresh outside air compressor. Yeah, that was the jet exception I had noted. You were lucky you didn't have to breath the compresser section air in that thing! The JT8 was OK AFAIK There would have been some fumes, but the RB-211 is a complete piece of junk. The Brits never could build an oil tight engine.... Bertie Damn, I wish they would have let you design it. It would have been perfect, uh. Couldn't have done any worse... Bertie From all that I heard, back when Eastern was flying L1011's, that is putting it politely. Still plenty of airplanes flying around with RB 211s as well. In fact, I've been on a few of Lufthansa's 146's and they reek of the **** as well. Bertie |
What is cabin air pressure set at | scm | General Aviation | 25 | October 16th 05 03:29 AM |
Cabin Air Pressure | [email protected] | Piloting | 9 | December 20th 04 03:07 PM |
Cabin Pressure Altitude | Greg Esres | Piloting | 4 | March 24th 04 08:35 PM |
Punctured pressure cabin. | M. J. Powell | Military Aviation | 103 | January 5th 04 06:16 AM |
Greatest Altitude without pressure cabin/suit | W. D. Allen Sr. | Military Aviation | 12 | July 26th 03 04:42 PM |
