Magneto Timing Question
Old August 22nd 08, 01:58 PM posted to rec.aviation.homebuilt
Charles Vincent
Default Magneto Timing Question
Dale Scroggins wrote:
How did the first A&P
set the timing; could he see the prop flange markings, or did he use a
timing wheel? The wheels can be inaccurate if improperly set up or if
the pointer friction is excessive.
I used to have a nifty device that installed into the plug hole on the
number one cylinder. It had a probe and a set of cards(each had marks
for several engines) that installed on it that would directly read the
cylinder position. The device was entirely mechanical and had a very
well made wooden box for a case. I inherited it and sold it years ago
since I wasn't likely to ever work on an R-2800 (most of the cards were
for big radials, but lycoming and continental were well represented as
well) I expected that it was probably standard kit for A&Ps
Charles
Old August 23rd 08, 01:39 AM posted to rec.aviation.homebuilt
150flivver
Charles
They're called Timerite and are still available but quite pricey.
MAGNETO TIMING LIGHT Plans Roger Owning 4 November 16th 05 05:24 PM
MAGNETO TIMING LIGHT Plans Roger Piloting 4 November 13th 05 07:50 PM
Bendix Magneto Question Dick Kurtz Owning 0 September 22nd 05 03:36 AM
Bendix Magneto Question Dick Kurtz Restoration 0 September 22nd 05 03:36 AM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 07:59 PM
