On Aug 22, 7:07*pm, 5Z wrote:
On Aug 22, 7:10*pm, Darryl Ramm wrote: It might blow a gasket if filled all the way due to hot temperatures and no expansion space. If it was altitude related leaving a larger air bubble would make problems due to pressure differential at altitude worse not better. Right? That makes sense, but since I've refilled mine, leaving the air bubble in there, it hasn't leaked. *Go figure. -Tom Tom, I was not disagreeing with your instructions, just the reasons you gave for doing so. My understanding is the air bubble is critical for fluid thermal expansion on the PZL since unlike some compasses they have no form of pressure relief diaphragm etc. Darryl |
I see 5Z keft his bubble in!
If the compass gets a big bubble inside can you replace the big bubble with a little one? If so where do you buy them and are they calibrated for size and expansion rates? Are they the same bubbles you get in spirit levels? K Ok wher do you buy the bubbles? Are they calibrated in any way?arted At 02:44 23 August 2008, Darryl Ramm wrote: On Aug 22, 7:07=A0pm, 5Z wrote: On Aug 22, 7:10=A0pm, Darryl Ramm wrote: It might blow a gasket if filled all the way due to hot temperatures and no expansion space. If it was altitude related leaving a larger air bubble would make problems due to pressure differential at altitude worse not better. Right? That makes sense, but since I've refilled mine, leaving the air bubble in there, it hasn't leaked. =A0Go figure. -Tom Tom, I was not disagreeing with your instructions, just the reasons you gave for doing so. My understanding is the air bubble is critical for fluid thermal expansion on the PZL since unlike some compasses they have no form of pressure relief diaphragm etc. Darryl |
Kate, how lucky can you be. I can supply bubbles of all sizes.
I can also supply: Think bubbles - Very useful when you are in trouble Holes - Metric and imperial Holes, water filled - Useful if you are unwell Gaps - Metric and imperial, magneto and spark Rests - for when you feel tired Ways and plots - For when you loose yours Bullsh1t - I have a surplus at the moment Lights - For dim buggers I am also developing a line in flatulence, varying fragrances - useful when you meet people you don't like. I am sorry I am right out of sense, common or otherwise and unlikely to have new stock in the forseeable future. Please send £10 sterling ($40) for a full catalogue. At 08:24 23 August 2008, Glider Kate wrote: I see 5Z keft his bubble in! If the compass gets a big bubble inside can you replace the big bubble with a little one? If so where do you buy them and are they calibrated for size and expansion rates? Are they the same bubbles you get in spirit levels? K Ok wher do you buy the bubbles? Are they calibrated in any way?arted At 02:44 23 August 2008, Darryl Ramm wrote: On Aug 22, 7:07=A0pm, 5Z wrote: On Aug 22, 7:10=A0pm, Darryl Ramm wrote: It might blow a gasket if filled all the way due to hot temperatures and no expansion space. If it was altitude related leaving a larger air bubble would make problems due to pressure differential at altitude worse not better. Right? That makes sense, but since I've refilled mine, leaving the air bubble in there, it hasn't leaked. =A0Go figure. -Tom Tom, I was not disagreeing with your instructions, just the reasons you gave for doing so. My understanding is the air bubble is critical for fluid thermal expansion on the PZL since unlike some compasses they have no form of pressure relief diaphragm etc. Darryl |
Compass | [email protected] | Soaring | 33 | February 27th 08 01:43 AM |
Compass for SZD-55 | Steve Freeman | Soaring | 3 | July 24th 07 02:13 AM |
PZL Compass | Dave Springford | Soaring | 3 | December 7th 05 04:05 AM |
compass turns with high mounted compass (Cessna 152) | Ray | Instrument Flight Rules | 22 | April 7th 05 07:39 AM |
mag-compass for a B55 | JerryK | Owning | 3 | July 11th 03 06:18 AM |
