On Aug 18, 4:11*pm, cavelamb himself wrote:
Bob Kuykendall wrote: On Aug 17, 5:27 pm, Fred the Red Shirt ...Here is where it gets interesting. *The lower longerons are curved. That means if those holes are drilled the same for the front and back longeron the axes about which those legs pivot will not be colinear, nor even parallel... Non-Euclidean geometry aside, that seems to me to be a rather sub- optimal design approach. Nothing that a couple of rod ends or rubber bushings couldn't fix. But it would probably be lighter and more effective to just make the gear leg holes colinear, and then build, adjust, or drill the fuselage to maintain that colinearity. You can't do that without changing the dimensions or the shape of the fuselage, which means you would not be building the fuselage per the plans. For instance, you could make the lower longeron straight between the two carry-throughs. But the plans call for it to be curved. You could put a wedge-shaped shim between either the forward or the read carry-through and the lower longeron, but none is called for in the plans. You could use angle with a wider leg on one side so as to be able to skew the bolt, but the size called out in the plans is not wide enough. If built according to the plans, the gear legs do not pivot freely. Just what bends, and how much when they do flex I do not know. It would be interesting if someone who has one under construction were to try to measure that while the fuselage is conveniently inverted. Which is the way it is done... I haven't seen ANY done that way. In every photo I have seen of the TP undercarriage not one shows the pivot bolts co-linear. In every case the bolt axes were parallel to the lower longeron, and therefor skewed with respect to each other. -- FF |
Heath Parasol plans, 103 trimmable? | Chris Wells | Home Built | 2 | July 1st 07 12:36 AM |
Texas Parasol and 1/2 VW Engine...... | WC | Home Built | 11 | June 4th 07 09:39 PM |
Looking for a good set of parasol plans | Mike Gaskins | Home Built | 11 | January 24th 07 04:10 AM |
Texas Parasol Plans... | Richard Lamb | Home Built | 82 | March 12th 06 07:19 AM |
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation | Richard Lamb | Home Built | 12 | August 9th 05 08:00 PM |
