effect of changed thrust line.
Old November 14th 08, 11:38 PM posted to rec.aviation.homebuilt
Alan Baker
Default effect of changed thrust line.
"Morgans" wrote:
wrote
Don't bother with center of mass. It's not really relevant.
Indeed
Angling the engine up 3.8 degrees would lead to trouble. That's a lot
of angle.
Absolutely
Thrust works against the center of DRAG, which is much harder
to locate than CG.
Thanks for a verification of my thinking.
Sorry.
But all forces on a body act around it's centre of *mass* when
considering its rotation. You can take the moments about anywhere fixed,
but the CoM is what actually matters.
As for angling the engine 3.8 degrees up being a bad idea, how can that
possibly be? When you pull up to a high AOA, does the engine suddenly
explode? No.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old November 15th 08, 12:03 AM posted to rec.aviation.homebuilt
Jim Logajan
Alan Baker wrote:
"Morgans" wrote:
Indeed
of angle.
Absolutely
to locate than CG.
Sorry.
I know you are trying to be helpful and you know that objects in free space
rotate about their center of mass, but I'm fairly confident that aspects
such as the center of pressure and affects on control surface authority
need to be taken into account when changing the thrust line.
explode? No.
A high angle of attack during cruise would presumably place the wings
closer to their stall angle. I presume that is what makes it dangerous.
Old November 15th 08, 12:20 AM posted to rec.aviation.homebuilt
Alan Baker
Jim Logajan wrote:
Alan Baker wrote:
"Morgans" wrote:
Indeed
of angle.
Absolutely
to locate than CG.
Sorry.
But by taking moments about the CoM, you can isolate the contribution of
the engine and work to keep it the same despite the change in its
location.
That's precisely why you don't do it with respect to loci that change.
Let's say the engine is mounted such that it is acting through the CoM,
OK? In that case, changes in thrust cannot *possibly* cause any net
torque, right?
OK, move the engine up or down, and if you reangle it to set the thrust
line through the CoM, then the same situation holds true.
explode? No.
Not dangerous for the engine, though, right?
Alan Baker
Old November 15th 08, 12:52 AM posted to rec.aviation.homebuilt
Morgans[_2_]
torque, right?
Yep. Drag is not at the center of mass
Nope. Drag is not at the CoM
Jim in NC
Old November 15th 08, 12:58 AM posted to rec.aviation.homebuilt
Alan Baker
torque, right?
What does that have to do with my question?
Take the air away for a moment and use a rocket. The only way to place
it such that it won't cause a pitching moment is to align its thrust
through the centre of mass, correct?
Show your work or a reference...
Alan Baker
thrust line for engine and not mounting engine on this thrust line tommyann Home Built 8 December 15th 06 03:31 PM
Has something changed [email protected] Soaring 10 May 3rd 05 08:34 PM
High thrust line on canard design? Shin Gou Home Built 4 March 5th 05 03:06 AM
Getting students to line up with the center line BoDEAN Piloting 27 April 21st 04 11:23 AM
I want to tell you something that has changed my life! C J Campbell Owning 11 January 29th 04 11:34 PM
