effect of changed thrust line.
Old November 18th 08, 04:41 AM posted to rec.aviation.homebuilt
John Kimmel
Default effect of changed thrust line.
On Sun, 16 Nov 2008 00:58:06 -0800, John Kimmel
Spreadsheet is not quite right.Prop center is BELOW the CG by about 13
inches.
One inch change in prop height according to your spreadsheat makes a
change of 2.14 degrees.
I cannot buy that. Particularly since it would go from 1.5 down to .64
up.
Here is REV A, with a couple math errors fixed:
http://www.spiretech.com/~guynoir/sl...thrustreva.xls
That looks a lot closer.
What is it based on?
"Vector Mechanics For Engineers: Statics and Dynamics", by Beer and Johnston, 5th edition, Chapter 4: "Equilibrium of Rigid Bodies",
page 126, equation 4.1. Equation 4.1 can be easily found on the internet, just type "statics" into Google and go to the first hit,
which should be Wikipedia.
All my spreadsheet does is keep the distance from the thrust line to the CG the same with different engine locations, so that the sum
of moments about the CG remains the same (as in: Zero. See equation 4.1).
John Kimmel
I think it will be quiet around here now. So long.
Old November 18th 08, 06:18 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
inches.
up.
Johnston, 5th edition, Chapter 4: "Equilibrium of Rigid Bodies", page
just type "statics" into Google and go to the first hit, which should be
Wikipedia.
I tried the first sheet.
Set the offset to 4 inches and got 8 something degrees angle!
That may have been a right answer for the problem you've set up.
But no way it would work on the airplane.
Richard
(remove the X to email)
Old November 18th 08, 08:02 AM posted to rec.aviation.homebuilt
John Kimmel
I checked the math on my rev a spread sheet more carefully than on the original, and included a check feature within the spreadsheet
itself. I also checked the spreadsheet graphically using a cad program. The spread sheet as currently posted will work for all
aircraft, but if you don't have a good understanding of the vector mechanics underlying it in the references I included in my previous
post, you should not use it.
If you think there is an error in my spread sheet, you are welcome to identify it, correct it, and re-post it, or you can show me the
problem graphically with a free body diagram and I'll make the correction, but your post above doesn't give me enough information.
John Kimmel
Old November 18th 08, 05:54 PM posted to rec.aviation.homebuilt
On Mon, 17 Nov 2008 20:41:30 -0800, John Kimmel
inches.
up.
Only problem I see is you still have it set up with the thrust above
the CG. The center line of the prop is significantly lower than the
CG. Do I just use negative numbers? Or should the spreadsheet still be
corrected?
Old November 19th 08, 05:47 AM posted to rec.aviation.homebuilt
On Tue, 18 Nov 2008 21:20:43 -0800, John Kimmel
corrected?
If you downloaded the corrected version, the numbers you see when you open the spreadsheet a
60 -13 -1.5 -14 -2.408899631
CG is 60" aft of propeller center. Propeller center is 13" below CG. Thrust angle is 1.5 degrees down.
If you move propeller center down 1" to 14" below CG, the new thrust angle will be 2.4 down.
That's what I suspected - and it seams to work. The resulting
reduction in the angle is counterintuitive however.
thrust line for engine and not mounting engine on this thrust line tommyann Home Built 8 December 15th 06 03:31 PM
Has something changed [email protected] Soaring 10 May 3rd 05 08:34 PM
High thrust line on canard design? Shin Gou Home Built 4 March 5th 05 03:06 AM
Getting students to line up with the center line BoDEAN Piloting 27 April 21st 04 11:23 AM
I want to tell you something that has changed my life! C J Campbell Owning 11 January 29th 04 11:34 PM
