Everyone has covered the topic well but I'll add my 2 cents having
repaired our 103 brake. Yes, it is a Magura master cylinder as used on BMWs. All they did was cut off most of the brake lever and mount a cable to the stub to actuate it. Yes, bleeding from the bottom of the system (slave) works best. Here's a little trick - any marine supply depot sells a plastic pump for replacing bottom end oil in outboard motors. It looks like a shampoo or epoxy pump and screws onto a standard oil, or coincidentaly, brake fluid bottle. Screw it on the bottle, push the tubing onto the cracked open caliper bleed nipple and pump slowly. It forces the brake fluid up. Have someone at the master cylinder with a towel wrapped around it to take care of overflow. It is always easier to force air bubbles upwards in a hydraulic system then to force them downwards. It is faster then from the top and a whole lot let frustrating. Another hint ... don't worry about replacing the entire master cylinder, Just go into a BMW motorcycle dealer and buy a rebuild kit (about $75). It includes a new piston, spring and seals. (I can't recall the bore size but these kits care reasonably universal - all you need to do it confirm the size at the parts desk.) Use a very fine emery cloth or wet sandpaper to gentle hone the cylinder and put it all together. Usually the problem is the seals, not pitting of the cylinder. Total job takes about 1.5 hours including removing and replacing the cylinder. |
Grob 103 Twin II (non acro) manual | YFCpilots | Soaring | 1 | August 27th 08 07:40 PM |
Grob Twin III Must read! | [email protected] | Soaring | 3 | June 9th 08 07:08 AM |
Grob Twin Astir Tailshaking | Peter | Soaring | 11 | January 14th 07 11:54 PM |
looking for good brake master cyls for homebuilt. | clare @ snyder.on .ca | Aviation Marketplace | 0 | March 28th 04 05:13 AM |
Need G-103 Acro Master Cylinder | Ray Lovinggood | Soaring | 5 | September 30th 03 03:39 AM |
