The + 12V power lead to my B40 fell out the back of the unit at some
point and made contact with ground during its subsequent tour of the area behind the panel. The (?)-amp, 5x20mm fuse in the instrument panel was blown, as well as the 0.25 amp fuse of the same size on the back of the B40. I know the purpose of the panel fuse is to protect the wires, and the B40 fuse is to protect the instrument (I think). Can I safely use a 0.25 amp fuse in the instrument panel and maybe a 0.5 amp fuse in the B40? (The B40 is the only item on that fuse; the radio, LX and 302 have their own.) Btw I've checked the B40 manual and can't find any mention of fuses. Is 0.25 amp the correct fuse? Thanks ~ted/2NO |
On Dec 8, 10:20*am, Tuno wrote:
The + 12V power lead to my B40 fell out the back of the unit at some point and made contact with ground during its subsequent tour of the area behind the panel. The (?)-amp, 5x20mm fuse in the instrument panel was blown, as well as the 0.25 amp fuse of the same size on the back of the B40. I know the purpose of the panel fuse is to protect the wires, and the B40 fuse is to protect the instrument (I think). Can I safely use a 0.25 amp fuse in the instrument panel and maybe a 0.5 amp fuse in the B40? (The B40 is the only item on that fuse; the radio, LX and 302 have their own.) Btw I've checked the B40 manual and can't find any mention of fuses. Is 0.25 amp the correct fuse? Thanks ~ted/2NO I don't see how the B40 fuse could have been blown if the power wire was disconnected. You may have another problem. If you don''t find an answer on the B40 fuse size call me at home (leave msg) and I'll check mine. Andy |
On Dec 8, 9:20*am, Tuno wrote:
The + 12V power lead to my B40 fell out the back of the unit at some point and made contact with ground during its subsequent tour of the area behind the panel. The (?)-amp, 5x20mm fuse in the instrument panel was blown, as well as the 0.25 amp fuse of the same size on the back of the B40. I know the purpose of the panel fuse is to protect the wires, and the B40 fuse is to protect the instrument (I think). Can I safely use a 0.25 amp fuse in the instrument panel and maybe a 0.5 amp fuse in the B40? (The B40 is the only item on that fuse; the radio, LX and 302 have their own.) Btw I've checked the B40 manual and can't find any mention of fuses. Is 0.25 amp the correct fuse? Thanks ~ted/2NO Ted, The fuse is 2 amp. Sometimes if +12v power touches the case of the B40 a fuse link on the circuit board on the back of the unit is blown. You can check this by following the circuit and using a voltmeter. Richard www.craggyaero.com |
| Thread Tools | |
| Display Modes | |
| Metric Fuse Question | Paul Foley | Soaring | 3 | August 21st 08 11:54 PM |
| Tube Fuse Oil Holes | John[_17_] | Home Built | 8 | March 21st 08 01:11 PM |
| KR-2 fuse for sale | Turbo Tiger | Home Built | 3 | December 17th 05 07:27 PM |
| Fuse the Wire or Fuse the Device? | ContestID67 | Soaring | 11 | April 27th 05 04:13 AM |
| Cambridge Fuse Question | Brian Iten | Soaring | 9 | January 4th 05 03:43 PM |
