Cobra Hydraulic Jack
Old December 12th 08, 08:45 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Default Cobra Hydraulic Jack
Hi Hartley,
I have a leaky jack from a 2001 Cobra trailer. Not sure if that is
considered old or new. Not sure where it leaks from, but I refill it
and it works ok for a variable period of time. Have considered
replacing it, but have not gotten around to it yet.
WD
Hi WD:
If you can, it would be helpful to try to locate the leak.
Next time you see a trace of leaking, wrap a half sheet of paper towel
around the piston which is driven by the foot lever. Wrap another around the
release valve stem (the lever that allows collapse) . With the jack
collapsed, as for storage, close the relese valve. Check frequently and one
of them will be oily.
Does it collapse in the raised position with weight on it? (this might
signify another problem altogether)
Let me know what you find.
Thanks
Hartley
Cobra hydraulic bottle jacks - where to buy? [email protected] Soaring 20 August 17th 17 06:15 AM
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) Glenn[_2_] Aviation Photos 0 September 19th 08 03:41 PM
Cobra Hydraulic Jack - oil replentishment Gary Emerson Soaring 4 March 25th 05 06:47 PM
Cobra jack warning Andy Durbin Soaring 8 June 30th 04 02:32 AM
Servicing Cobra Hydraulic foot pumps mike pitoniak Soaring 13 March 9th 04 04:04 PM
