On Jan 8, 12:22*pm, Tim Taylor wrote:
On Jan 8, 9:57*am, wrote: On Jan 8, 11:08*am, Andy wrote: On Jan 8, 8:45*am, wrote: Even in the worst case presented, the new rule is still a significant improvement. Sorry, I don't agree. If the intent of the rule change is to prevent starts from the back half there are better ways to do it. The rule should define the "front half" as the semicircle of the start cylinder that has its diameter normal to the line between the start point and the first turn point. *A valid start would only be given for an exit from the front half. The valid start area is then fixed for all contestants regardless of where they turn in the first area. *This valid start area is easily visualized by the contestant without needing any special computer software. Andy Yes, I do think it's an improvement. *Your version is even better in its simplicity. I've never seen anyone start from the back of the circle, either, though I've only flown a couple of regionals since start anywhere was adopted. *However I can think of a few contest numbers that I would expect to see trying this, sooner or later. *I'd rather *not* fly this way myself, but probably *would* if it was necessary to be competitive. *I rather we had a rule that took away any incentive to do this. -T8 Evan, I'm not sure what you mean by "rather *not* fly this way". *Is this in reference to starting near the back of the cylinder or something else? I have flown at several sites that I could easily see starting near the back of the cylinder. *I nearly did it a few years ago even with the 10 mile penalty back then because I could climb 7,000 feet higher near the back than the front at Air Sailing when we had tasks to the south. At Parowan, Minden Logan, and Air Sailing depending on the start cylinder and the location of the first turn point, there can be a great reason to go to the back of the cylinder and climb on the higher ground. The proposed rules seems to add nothing but confusion and complexity to a very simple idea. Start anywhere in the cylinder or out the top. Score the distance from the startpoint to the turnpoint. The start anywhere is a vast improvement over the old system. *At Uvalde with the top of the cylinder above cloud base you had one or two thermals on the closest edge of the cylinder with pilots pushing into the wisps and the usual gaggle compression at the top. *I will take Start Anywhere over that anytime. TT Hi Tim, Long time since Albert Lea, eh? Starting through the top of the cylinder (and staying on top) doesn't bother me a bit. I just never seem to get the opportunity to do it. Both regionals I flew this year (R1, R4S) had gates with tops well above cloud base and in one case the cloud bases were extremely variable just to spice things up. In no case did I see anyone do anything dumb or even remotely ungentlemanly in the gate. But at times it did feel a bit crowded close to cloud, er, cloud clearance minimums. What I was referring to was the (so far, largely theoretical) practice of starting at the back and then flying through the cylinder below max altitude. The theory is that you'd make good time by using all the pre-start gaggles. The proposed rule is an attempt to head off that temptation before it becomes troublesome. -T8 |
On Jan 8, 11:00*am, wrote:
On Jan 8, 12:22*pm, Tim Taylor wrote: On Jan 8, 9:57*am, wrote: On Jan 8, 11:08*am, Andy wrote: On Jan 8, 8:45*am, wrote: Even in the worst case presented, the new rule is still a significant improvement. Sorry, I don't agree. If the intent of the rule change is to prevent starts from the back half there are better ways to do it. The rule should define the "front half" as the semicircle of the start cylinder that has its diameter normal to the line between the start point and the first turn point. *A valid start would only be given for an exit from the front half. The valid start area is then fixed for all contestants regardless of where they turn in the first area. *This valid start area is easily visualized by the contestant without needing any special computer software. Andy Yes, I do think it's an improvement. *Your version is even better in its simplicity. I've never seen anyone start from the back of the circle, either, though I've only flown a couple of regionals since start anywhere was adopted. *However I can think of a few contest numbers that I would expect to see trying this, sooner or later. *I'd rather *not* fly this way myself, but probably *would* if it was necessary to be competitive. *I rather we had a rule that took away any incentive to do this. -T8 Evan, I'm not sure what you mean by "rather *not* fly this way". *Is this in reference to starting near the back of the cylinder or something else? I have flown at several sites that I could easily see starting near the back of the cylinder. *I nearly did it a few years ago even with the 10 mile penalty back then because I could climb 7,000 feet higher near the back than the front at Air Sailing when we had tasks to the south. At Parowan, Minden Logan, and Air Sailing depending on the start cylinder and the location of the first turn point, there can be a great reason to go to the back of the cylinder and climb on the higher ground. The proposed rules seems to add nothing but confusion and complexity to a very simple idea. Start anywhere in the cylinder or out the top. Score the distance from the startpoint to the turnpoint. The start anywhere is a vast improvement over the old system. *At Uvalde with the top of the cylinder above cloud base you had one or two thermals on the closest edge of the cylinder with pilots pushing into the wisps and the usual gaggle compression at the top. *I will take Start Anywhere over that anytime. TT Hi Tim, Long time since Albert Lea, eh? Starting through the top of the cylinder (and staying on top) doesn't bother me a bit. *I just never seem to get the opportunity to do it. Both regionals I flew this year (R1, R4S) had gates with tops well above cloud base and in one case the cloud bases were extremely variable just to spice things up. *In no case did I see anyone do anything dumb or even remotely ungentlemanly in the gate. *But at times it did feel a bit crowded close to cloud, er, cloud clearance minimums. What I was referring to was the (so far, largely theoretical) practice of starting at the back and then flying through the cylinder below max altitude. *The theory is that you'd make good time by using all the pre-start gaggles. *The proposed rule is an attempt to head off that temptation before it becomes troublesome. -T8 Evan, Thanks for the explanation. Yes, many years since Albert Lea, HP-18's and Std Cirri. What you describe can still happen with the new rules so I guess I don't see the point in trying to make the rule more complex. I can climb up right at the center of the cylinder and dive through the gaggle five miles ahead as long as I don't stay in the cylinder longer than 2 minutes. Maybe we need to shorten that time to 1 minute so they are likely to get a new start time and make the whole idea of hitting the front edge worthless. I like the Start Anywhere because it uses real distance so I can go over 80 degrees off course line between the center of the start cylinder and the first turnpoint and start out the side. The proposed change will have everyone starting in a very narrow range on the front edge to ensure we get all the distance and we are all back in the same gaggle again. Hope you drag your ship out west and run some ridges with us in UT, Tim (TT) |
On Jan 8, 10:41*am, Tim Taylor wrote:
*What you describe can still happen with the new rules so I guess I don't see the point in trying to make the rule more complex. *I can climb up right at the center of the cylinder and dive through the gaggle five miles ahead as long as I don't stay in the cylinder longer than 2 minutes. *Maybe we need to shorten that time to 1 minute so they are likely to get a new start time and make the whole idea of hitting the front edge worthless. Good points Tim. It feels like an attempt to solve a problem that doesn't happen much and in doing so negates some of the benefits of the original rule change while only halfway meeting the objective of making the "bump and run" strategy hard to pull off when it is an option. Andy's suggestion of a fixed front half should work - with the understanding that under the worst case scenario a pilot could technically line up a course line that ran for 10 miles along the straight edge of the half-cylinder - just the way the angles work out. Would it happen very often? Who the heck knows? It would be simpler to understand. The other possible approach would be to make the start cylinder smaller (like 3 miles) - no software re-programming required. I like the bigger cylinder, but it would be an easier experiment to run in 2009. 9B |
On Jan 8, 12:15�pm, wrote:
On Jan 8, 10:41�am, Tim Taylor wrote: �What you describe can still happen with the new rules so I guess I don't see the point in trying to make the rule more complex. �I can climb up right at the center of the cylinder and dive through the gaggle five miles ahead as long as I don't stay in the cylinder longer than 2 minutes. �Maybe we need to shorten that time to 1 minute so they are likely to get a new start time and make the whole idea of hitting the front edge worthless. Good points Tim. �It feels like an attempt to solve a problem that doesn't happen much and in doing so negates some of the benefits of the original rule change while only halfway meeting the objective of making the "bump and run" strategy hard to pull off when it is an option. Andy's suggestion of a fixed front half should work - with the understanding that under the worst case scenario a pilot could technically line up a course line that ran for 10 miles along the straight edge of the half-cylinder - just the way the angles work out. Would it happen very often? Who the heck knows? It would be simpler to understand. The other possible approach would be to make the start cylinder smaller (like 3 miles) - no software re-programming required. I like the bigger cylinder, but it would be an easier experiment to run in 2009. 9B The rules are written as an agreement between several parties. This agreement requires all entrants to be in agreement with the rules and each other. All entrants must be on equal ground and must not be required to have special, expensive software which only a few can afford. If one wishes to start anywhere within the defined start circle, or turn anywhere they choose within the defined turn area, they must not have the fear that if they don't have the new and expensive software they might not recieve their flown distance. The problem is trying to make something work that has these restrictions which has been pointed out by several of you. I do believe the rules committee has seen this and is working on it. If starting out the top is what is normally not done by almost all the entrants, has not been normally seen, then simply stop it. Most contest managers that I have spoken with, starting out the top is their worst fear for possible problems. This one point of starting out the top was the underlying reason why the NSF closed its doors in Hobbs. They were very concerned about one hot jock starting out the top and bouncing his way thur the gaggles. I was their, I saw the IGC files, and became very involved with this topic. We finally got a finish which you can't pull up into. I, and another, almost got knifed in half, when someone pulled up right in front of us inside the circle, during the finish. We were at 500 agl. and chutes don't work from 500 ft. agl. How can this "new start anywhere" be a "start anywhere" when you can't do that? That's the crazest dang thing I ever heard. Almost all of us forgot their geometry 101 in high school. New entrants (or any entrants) flying in any class should be able to understand the rules and not feel they are at a disadvange before they even get to the contest. They won't even come. The contest, yes, the contest, should not start before the start. The start must be fair and equal to all entrants. Not just to a few who have more knowledge than most of us. Many thanks to both Andy's on bring this up. I do believe the rules committee is working on this, because BB hasn't shown up yet and told us different. I do believe what the rules committee is trying to do is stop the starting out the rear half, why? because if the first leg is downwind, its best to start as far upwind as you can, as it makes the last leg home into the wind shorter, which saves time. Remember well that XX talks about saving seconds. By starting up near one side of the circle you can again use the wind, maybe a quartering tail wind, to fly to the far otherside of the first turn circle, again saving time. Remember, even on blue days, streets of lift do line up, reread A J Smith on this. Now, new folks don't read RAS and most of you already knew this, so I feel safe in talking about this. But, is this fair to all entrants? As long as I win, it sure is..........cause I will tell them they could of read it on RAS............. Thermal tight, Soar high, Fly safe........#711. |
| Thread Tools | |
| Display Modes | |
| FAA publishes proposed changes to amateur-built rules. | Jim Logajan | Home Built | 19 | July 28th 08 09:30 AM |
| 2009 U.S. Contest Locations/Dates | Tim[_2_] | Soaring | 2 | February 28th 08 06:48 PM |
| 2008 Proposed US Competition Rules Changes | [email protected] | Soaring | 18 | December 31st 07 08:21 PM |
| US Contest Rules Proposed Changes for 2006 | Ken Sorenson | Soaring | 18 | January 12th 06 05:30 PM |
| Proposed 2005 Rules On SRA Site | Ken Kochanski (KK) | Soaring | 79 | January 27th 05 07:51 PM |
