F-16 glider
Old January 18th 09, 03:07 PM posted to rec.aviation.soaring
kirk.stant
Default F-16 glider
On Jan 18, 5:45*am, Gavin Short wrote:
At 20:00 17 January 2009, wrote:
Apparently the glide ratio of an F-16 with the engine out is 1:1 so the
pilot's rate of breathing in the video clip is impressively calm!
Well, it's a little better than that. When practicing SFOs (simulated
flame out) approaches, the rule of thumb (and this is from memory so
any F-16 drivers out there please jump in!) was 250 knots clean and
6:1 to the field; i.e. you needed 1000' for every nautical mile from
your intended touchdown point. Tried it several times in F-16
simulators at Luke AFB and it worked fine (lots of fun, too -
sometimes the hardest part was getting it stopped!). So the L/D is at
least 6:1, probably as high as 10:1 clean at L/D max speed.
OTOH, the F-4E flight manual (that I just happen to have handy) is
very explicit on what to do with both engines out:
"If neither engine can be started - EJECT"
Kirk
66
Old January 18th 09, 10:32 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default F-16 glider
flame out) approaches, the rule of thumb (and this is from memory so any
F-16 drivers out there please jump in!) was 250 knots clean and 6:1 to
the field; i.e. you needed 1000' for every nautical mile from your
I noticed that the film showed the airspeed pretty much nailed at 220 kts
until he started to flare. Couldn't get anything from the altimeter
display - hard to read off low-rez viseo!
I thought the glide ratio had to be better than 1:1 because even the
Shuttle manages 3:1 and an F-16 looks as it it should do rather better
than that.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Exporting a glider to/import a glider into Germany Pete Smith[_2_] Soaring 1 August 8th 08 09:33 AM
Jet Glider 33 Soaring 5 March 19th 08 03:09 AM
Glider art Mal Soaring 2 December 13th 06 06:54 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
