On Jan 19, 9:27*am, Martin Gregorie
wrote: On Mon, 19 Jan 2009 08:25:29 -0800, Darryl Ramm wrote: As for wanting a Mode-S transponder with "TCAS" display. You can get this today. In the USA PCAS units like the Zaon MRX are popular and use very low power and relatively low cost (~$500). They provide an alert but no RA or direction information. I, for one, appreciate that Mode-S plus PCAS will do the full electronic see-and-be-seen bit, but its a two box solution with any instruments I've seen advertised. Some of us just don't have the panel space for that. I fly a Libelle and currently have all panel holes bar one full. The blanking plate in the remaining one supports my GPS on a stalk. Nonetheless, I think I can get a 57mm transponder in alongside the stalk mount, but that will certainly need a replacement panel chassis and may need my 80mm altimeter to be replaced with a 57mm unit. That exercise leaves me with the transponder, but where can I put the PCAS? In a Libelle there's no way it can be put on top of the panel and there is little if any available space along the cockpit sides. This is why I, for one, really need a single, 57mm instrument combines both transponder and PCAS and is low power enough to run off a glider battery. If such an instruments exists I'd love to know the details. Derek is right about our airspace: I've never met anything other than * other gliders, GA aircraft, a few helicopters, the odd hang glider/ parascender and one or two military aircraft when I've been on an xc task. The usual opposition to a glider on an xc task is GA pilots. I bet they don't carry PCAS/TCAS and I'm not under ATC control. Under these conditions the introduction of transponders does not reduce my changes of a collision unless I have PCAS onboard. Hence my interest in the combined instrument. * -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. Companies who make panel mounted transponders usually do so for the larger GA market and they have to coexist with all sorts of PCAS, active systems (like the Avidyne) and full on TCAS. I would not hold my breath for a transponder with integrated PCAS. But maybe now manufacturers will be making them mostly for UAVs and those UAVs could do with integrated PCAS :-( In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy, it might be canted over parallel to the surface, and use an antenna mounted on suction cups on the canopy. Obviously paying attention to canopy jettison issues. I'd be kind of surprised it is impossible, but not saying its going to be trivial. Darryl |
The part of the discussion about UK use of transponders has missed out
what I consider the main point, which is the complex regulatory requirements placed on us for fitting transponders. First, you can now only install approved kit, and our CAA imposes more stringent requirements for approval than other aviation regulators. Second, installation can only be done, as I understand it, if either (a) the manufacture has issued an approved scheme for installation (I believe none have, other than for motor gliders), or (b) if you pay an installer to produce a formal modification scheme (fees) and then pay our CAA substantial "major modification" fees to have the scheme approved. On top of this there are further substantial fees for annual tests. Currently, it is unlawful just to fit a transponder yourself or to get a knowledgeable person to do so for you (or maybe it's lawful to do this, but then unlawful to fly the aircraft). Far be it from me to say that preventing voluntary transponder carriage is foolish, but ... Darryl Ramm wrote: I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. Companies who make panel mounted transponders usually do so for the larger GA market and they have to coexist with all sorts of PCAS, active systems (like the Avidyne) and full on TCAS. I would not hold my breath for a transponder with integrated PCAS. But maybe now manufacturers will be making them mostly for UAVs and those UAVs could do with integrated PCAS :-( In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy, it might be canted over parallel to the surface, and use an antenna mounted on suction cups on the canopy. Obviously paying attention to canopy jettison issues. I'd be kind of surprised it is impossible, but not saying its going to be trivial. Darryl |
On Jan 19, 10:18*am, Chris Reed wrote:
Second, installation can only be done, as I understand it, if either (a) the manufacture has issued an approved scheme for installation (Ibelieve none have, -------------------------------------------------------------------- DG has a TN for the installation, probably others do as well, but you have to dig a bit for it. I agree that the power issue might not be that important. Selecting a lower current encoder (ACK?) can help. For my installation I installed wiring for a second battery but am waiting to see if it's really needed. It might only be required for unusually long flights, and in those cases might be avoided by using a 'load shedding' check list- by using the back-up battery in the vario, shifting the PDA to it's internal battery, and avoiding idle chatter on the radio you get some extra hours. |
Schempp-Hirth has TNs for transponders as well - permitting three different
antenna types - blade, rod or bendy. The new Trig Avionics TT21 transponder, with built-in altitude encoder is estimated by the makers to consume 320 mA from a 12 V battery when busy. Assuming the 7Ah battery is only delivering 50% of nominal capacity this equates to 10 hours continuous use. The controller that needs to be accessed by the pilot is 6.4 x 4.5 x 4.5 cm, the transponder itself can be installed anywhere convenient in the glider so will fit most gliders. (And I don't have an interest in it.) At 22:47 19 January 2009, brianDG303 wrote: On Jan 19, 10:18=A0am, Chris Reed wrote: Second, installation can only be done, as I understand it, if either (a) the manufacture has issued an approved scheme for installation (Ibelieve none have, -------------------------------------------------------------------- DG has a TN for the installation, probably others do as well, but you have to dig a bit for it. I agree that the power issue might not be that important. Selecting a lower current encoder (ACK?) can help. For my installation I installed wiring for a second battery but am waiting to see if it's really needed. It might only be required for unusually long flights, and in those cases might be avoided by using a 'load shedding' check list- by using the back-up battery in the vario, shifting the PDA to it's internal battery, and avoiding idle chatter on the radio you get some extra hours. |
So do the many wooden and vintage gliders still flying have TNs from their
manufacturers for fitting Mode S transponders then? Somehow I rather doubt it! Derek C At 00:15 20 January 2009, Big Wings wrote: Schempp-Hirth has TNs for transponders as well - permitting three different antenna types - blade, rod or bendy. The new Trig Avionics TT21 transponder, with built-in altitude encoder is estimated by the makers to consume 320 mA from a 12 V battery when busy. Assuming the 7Ah battery is only delivering 50% of nominal capacity this equates to 10 hours continuous use. The controller that needs to be accessed by the pilot is 6.4 x 4.5 x 4.5 cm, the transponder itself can be installed anywhere convenient in the glider so will fit most gliders. (And I don't have an interest in it.) At 22:47 19 January 2009, brianDG303 wrote: On Jan 19, 10:18=A0am, Chris Reed wrote: Second, installation can only be done, as I understand it, if either (a) the manufacture has issued an approved scheme for installation (Ibelieve none have, -------------------------------------------------------------------- DG has a TN for the installation, probably others do as well, but you have to dig a bit for it. I agree that the power issue might not be that important. Selecting a lower current encoder (ACK?) can help. For my installation I installed wiring for a second battery but am waiting to see if it's really needed. It might only be required for unusually long flights, and in those cases might be avoided by using a 'load shedding' check list- by using the back-up battery in the vario, shifting the PDA to it's internal battery, and avoiding idle chatter on the radio you get some extra hours. |
On Jan 19, 6:45*pm, Derek Copeland wrote:
So do the many wooden and vintage gliders still flying have TNs from their manufacturers for fitting Mode S transponders then? Somehow I rather doubt it! Derek C * At 00:15 20 January 2009, Big Wings wrote: Schempp-Hirth has TNs for transponders as well - permitting three different antenna types - blade, rod or bendy. The new Trig Avionics TT21 transponder, with built-in altitude encoder is estimated by the makers to consume 320 mA from a 12 V battery when busy. Assuming the 7Ah battery is only delivering 50% of nominal capacity this equates to 10 hours continuous use. The controller that needs to be accessed by the pilot is 6.4 x 4.5 x 4.5 cm, the transponder itself can be installed anywhere convenient in the glider so will fit most gliders. *(And I don't have an interest in it.) At 22:47 19 January 2009, brianDG303 wrote: On Jan 19, 10:18=A0am, Chris Reed *wrote: Second, installation can only be done, as I understand it, if either (a) the manufacture has issued an approved scheme for installation (Ibelieve none have, -------------------------------------------------------------------- DG has a TN for the installation, probably others do as well, but you have to dig a bit for it. I agree that the power issue might not be that important. Selecting a lower current encoder (ACK?) can help. For my installation I installed wiring for a second battery but am waiting to see if it's really needed. It might only be required for unusually long flights, and in those cases might be avoided by using a 'load shedding' check list- by using the back-up battery in the vario, shifting the PDA to it's internal battery, and avoiding idle chatter on the radio you get some extra hours. Well Schleicher has a TM concerning the installation of a transponder for my Ka-6 http://alexander-schleicher.de/tm/06/060_TM24_D.pdf Still doesn't address the cost issue though Pete |
On Jan 19, 1:18*pm, Chris Reed wrote:
Second, installation can only be done, as I understand it, if either (a) the manufacture has issued an approved scheme for installation (I believe none have, other than for motor gliders), or (b) if you pay an installer to produce a formal modification scheme (fees) and then pay our CAA substantial "major modification" fees to have the scheme approved.. Lange gliders have transponder antenna mount built-in, and most are delivered with antenna and wiring installed with transponder... Includes Antares 18 pure glider... |
On Mon, 19 Jan 2009 10:06:40 -0800, Darryl Ramm wrote:
I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. Yes, agreed. The public will be with us on noise grounds if the commuter airlines get their way and start flying direct routes through class G airspace - this is something they can't do at present, but the CAA's transponder consultation seems designed to let them do it. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. I've not seen figures either, but the GA density is probably lower here. There are flying schools on either side of our club field and there's no doubt that our weekend movements vastly outnumber both of theirs. In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy. There's less space there than you might imagine. The panel is inset no more than 65mm (2.5"), so an end-on cigarette pack would not fit under in font of the panel while anything thicker would start to hide the top row instruments. It might be canted over parallel to the surface, It would have to be. If it was in the center it would interfere with the canopy lock. On the other hand, the antenna is probably not an issue - a remote one could be mounted above the instrument tray that forms the front of the panel. My GPS antenna is mounted there and gets an excellent view of the sky. I wouldn't want anything much bigger than a MH flowmeter on the cockpit wall in front of me: lets just say the cockpit is 'snug'. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Jan 19, 4:24*pm, Martin Gregorie
wrote: On Mon, 19 Jan 2009 10:06:40 -0800, Darryl Ramm wrote: I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. Yes, agreed. The public will be with us on noise grounds if the commuter airlines get their way and start flying direct routes through class G airspace - this is something they can't do at present, but the CAA's transponder consultation seems designed to let them do it. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. *I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. I've not seen figures either, but the GA density is probably lower here. There are flying schools on either side of our club field and there's no doubt that our weekend movements vastly outnumber both of theirs. In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy. There's less space there than you might imagine. The panel is inset no more than 65mm (2.5"), so an end-on cigarette pack would not fit under in font of the panel while anything thicker would start to hide the top row instruments. It might be canted over parallel to the surface, It would have to be. If it was in the center it would interfere with the canopy lock. On the other hand, the antenna is probably not an issue - a remote one could be mounted above the instrument tray that forms the front of the panel. My GPS antenna is mounted there and gets an excellent view of the sky. I wouldn't want anything much bigger than a MH flowmeter on the cockpit wall in front of me: lets just say the cockpit is 'snug'. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | The proponents of transponders in gliders should study a recent Transportation Safety Board of Canada investigation report into a tragic mid-air collision between a Cessna 182 and a Cessa near Toronto in August 2006. Three people died in the collision. The full investigation report is available on the TSB web site at http://www.tsb.gc.ca/eng/rapports-re...6/a06o0206.asp The TSB report states: "Both aeroplanes were operating in accordance with visual flight rules in Class E airspace....Both aeroplanes were equipped with functioning transponders. C-GCHN was also equipped with a traffic information service (TIS) system that can provide a display of nearby aircraft using information provided by ground-based radar; this service is not available in Canada." A transponder can reduce the risk of collision with Traffic Collision Advisory System (TCAS) equipped aircraft, i.e. mostly air transport category aircraft. Maybe that reduction in risk is worth the cost in some places. However, as this accident shows, simply installing a transponder gives no guarantee against collision with non-TCAS equipped aircraft. Ian Grant Ottawa Canada |
Hi Gang
Without belaboring it I think it has been said enough times that currently there is no single fool proof way to guaranty avoiding mid airs. Having an operating transponder, without argument, will diminish your chance of a mid air since both ATC and aircraft with TCAS or PCAS will see you. You may not see them and that is why in my world, without argument, you should also have, at the minimum, a PCAS so that you will see another aircraft with an operating transponder. A Zaon PCAS can be had for only $500 - a trivial amount when it comes to safety. I don't know why we are still discussing these issues - transponders and PCAS are mandatory safety devices in my world. I can't think of a reason why anyone would think otherwise. Dave On Jan 22, 11:35*am, wrote: On Jan 19, 4:24*pm, Martin Gregorie wrote: On Mon, 19 Jan 2009 10:06:40 -0800, Darryl Ramm wrote: I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. Yes, agreed. The public will be with us on noise grounds if the commuter airlines get their way and start flying direct routes through class G airspace - this is something they can't do at present, but the CAA's transponder consultation seems designed to let them do it. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. *I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. I've not seen figures either, but the GA density is probably lower here.. There are flying schools on either side of our club field and there's no doubt that our weekend movements vastly outnumber both of theirs. In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy. There's less space there than you might imagine. The panel is inset no more than 65mm (2.5"), so an end-on cigarette pack would not fit under in font of the panel while anything thicker would start to hide the top row instruments. It might be canted over parallel to the surface, It would have to be. If it was in the center it would interfere with the canopy lock. On the other hand, the antenna is probably not an issue - a remote one could be mounted above the instrument tray that forms the front of the panel. My GPS antenna is mounted there and gets an excellent view of the sky. I wouldn't want anything much bigger than a MH flowmeter on the cockpit wall in front of me: lets just say the cockpit is 'snug'. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | The proponents of transponders in gliders should study a recent Transportation Safety Board of Canada investigation report into a tragic mid-air collision between a Cessna 182 and a Cessa near Toronto in August 2006. Three people died in the collision. The full investigation report is available on the TSB web site athttp://www.tsb.gc..ca/eng/rapports-reports/aviation/2006/a06o0206/a06o... The TSB report states: "Both aeroplanes were operating in accordance with visual flight rules in Class E airspace....Both aeroplanes were equipped with functioning transponders. C-GCHN was also equipped with a traffic information service (TIS) system that can provide a display of nearby aircraft using information provided by ground-based radar; this service is not available in Canada." A transponder can reduce the risk of collision with Traffic Collision Advisory System (TCAS) equipped aircraft, i.e. mostly air transport category aircraft. Maybe that reduction in risk is worth the cost in some places. However, as this accident shows, simply installing a transponder gives no guarantee against collision with non-TCAS equipped aircraft. Ian Grant Ottawa Canada |
Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Piloting | 155 | May 10th 08 02:45 PM |
Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 12 | May 1st 08 03:42 PM |
Feds Want to Equipe Gliders With Transponders and Radios | Alan[_6_] | Soaring | 3 | May 1st 08 03:30 PM |
Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 0 | April 28th 08 04:22 AM |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
