On Thu, 19 Feb 2009 23:47:51 -0600, "Highflyer" wrote:
"pintlar" wrote in message ... I was lead to believe the B-52's wing took a negative angle of attack when the engines lost power. For the crew, that is nice to know that this is not true. I think you will find, with ANY airplane, that the angle of attack is solely dependant upon the airspeed and the weight. It would not be expected to change in any way by any power setting, from zero to max. Notice that this is definately NOT true for a powered rotary wing aircraft! :-) Highflyer Highflight Aviation Services Pinckneyville Airport PJY It is not at all uncommon for a plane to "change trim" with application of power - add power and many planes will "nose up" slightly, and back the power down and they "nose down". This is preferable to the opposite condition, which can happen on the likes of a Lake or SeaBee. Upthrust od downthrust designed into the mount combined with the location of the engine is usually calculated to reduce the effect by tending to cancel each other out, but the combination is not always totally effective. |
airbus - Latest Plane From Airbus.jpg | [email protected] | Aviation Photos | 14 | June 26th 07 09:41 AM |
Which is easier: Boeing to Airbus, or Airbus to Boeing? | Mxsmanic | Piloting | 9 | February 21st 07 01:58 AM |
A question on Airbus landings | [email protected] | Piloting | 17 | July 18th 06 09:05 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Airbus | Ace | Simulators | 0 | March 2nd 05 05:13 PM |
