On Feb 20, 3:58*am, chris wrote:
Good feedback so far. *Just to clarify: I'm just trying to do spot repairs, [at least right now for this season]. *The gel is chipping off in small pieces the size of a, grain of rice, fingernail clipping to the size of a full fingernail/small coin. *So I don't think spraying makes sense. *Getting sandpaper into the spot is difficult because some areas are no wider than they are deep, and you have to be careful to not scratch the main clear part of the canopy that is directly adjacent. The chips are the full thickness / single layer of gel. *It is about as thick as 2-3 pieces of paper. Maybe I should consider next year having it all stripped down, all the gel removed and a totally redone, right now I just need to get patched for the spring. If I put primer on the plexiglass, would gelcoat adhere to a layer of paint primer? Chris Just put some tape over it. |
another gelcoat story | Brad[_2_] | Soaring | 1 | August 24th 08 06:37 PM |
Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 08:07 PM |
Fiberglass adhesion to aluminum? | [email protected] | Home Built | 19 | January 7th 06 03:58 PM |
Canopy Closing Problem | [email protected] | Soaring | 4 | October 12th 05 05:52 AM |
Gelcoat and solvents | Nolaminar | Soaring | 7 | May 16th 04 11:15 PM |
