Canopy Closing Problem
Old October 11th 05, 06:05 PM
Default Canopy Closing Problem
The hot weather canopy closing problem is often due to the plexiglas's
high thermal coefficient of expansion, and hot weather. The canopy
expansion is much higher than that of most fuselage composites. The
manufacturers generally ship their sailplanes with nicely fitting
canopies, when the air temps are about 75 degrees F (I think). So when
we bring them to our hot summers here, it is really necessary to sand
some of the forward and aft edges of the canopy to get them to close
properly.
A strip of carbon paper placed in the canopy gap before closing will
clearly mark the interfering areas. I try to sand the canopy frame only
to achieve the needed clearances.
I remember the Polish Team sanding vigorously on their canopies when
they first came to Uvalde for the 1991 Worlds Championships.
Old October 12th 05, 12:00 AM
Mal
Cool water on the canopy does the trick.
Old October 12th 05, 01:57 AM
Andy
Until you land and find you can't open it.
Old October 12th 05, 05:36 AM
I had a similar problem when I was flying a Ventus B. If help was
available, having someone push down on the nose distorted the fuselage
just enough to allow the canopy to close without too much trouble. I
tried the sanding route too with little improvement.
Between heat and humidity you can have some significant expansion in
materials. Most canopies are made from a material that is hygroscopic
and if you move your glider from a dry climate to a wet/humid one, you
can count on seeing and feeling the effects.
The forward hinged canopies seem to tolerate these effects better.
Respectfully,
Pegasus comparisons sought Ted Wagner Soaring 9 January 24th 04 04:36 AM
Help, Need Complete Front Canopy for Grob 103 Carl Buehler Soaring 0 December 28th 03 02:15 AM
Canopy... Clear Green or Blue ? CH Soaring 8 September 15th 03 02:14 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
