Rust removal?
Old February 25th 09, 08:47 PM posted to rec.aviation.soaring
noel.wade
Default Rust removal?
Hi All,
Hopefully a simple quick question:
I pulled my glider out of the trailer after a long winter recently,
and found that I hadn't greased my lift-pins quite well enough. There
are a few small spots of surface corrosion on them, and I'd like to
get rid of it.
BUT, given the importance of the lift pins I don't want to just go
grinding on them. Anyone have any suggestions on the best/least-
destructive way to get rid of minor surface rust/corrosion on parts
like this?
Thanks a bunch,
--Noel
Old February 25th 09, 08:53 PM posted to rec.aviation.soaring
Craig[_2_]
On Feb 25, 12:47*pm, "noel.wade" wrote:
Hi All,
and found that I hadn't greased my lift-pins quite well enough. *There
get rid of it.
grinding on them. *Anyone have any suggestions on the best/least-
like this?
Thanks a bunch,
--Noel
A green scotchbrite pad lubricated with WD-40 or LPS, etc, does a good
job of pulling up surface corrosion without significantly influencing
the parent material.
Craig
Old February 25th 09, 09:12 PM posted to rec.aviation.soaring
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Craig
Good suggestion. But if that doesn't remove it all, try a fine steel
wool. Start gently, then buff and lubricate when satisfied.
Jeff 7JK
Old February 25th 09, 10:47 PM posted to rec.aviation.soaring
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Craig
Jeff * * 7JK- Hide quoted text -
- Show quoted text -
Naval Jelly, then rinse well
Aerodyne
Old February 26th 09, 02:26 AM posted to rec.aviation.soaring
JJ Sinclair
Come on guys, those pins are 10 times stronger than they need to
be..............sand off the rust with 220 or emery cloth and lube
them next time. I keep my pins in two large plastic tubes with lube
inside (duct-taped together) as I remove them they pick up just
enpough lube to shove them home.
JJ
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Craig
Aerodyne
Old February 26th 09, 02:31 AM posted to rec.aviation.soaring
ZZ
noel.wade wrote:
Hi All,
get rid of it.
like this?
Thanks a bunch,
--Noel
Noel
To prevent this in the future try this. Mix some LPS 3 (very waxy) and
white lithium grease into a paste and coat any metal surface that you do
not want to rust. It's very effective, easy to remove in the Spring and
cheap.
Paul
ZZ
Old February 26th 09, 11:48 AM posted to rec.aviation.soaring
JJ
Hey JJ - any reason to be concerned about the tightness of the fit of
the pins in the bushings? I'd think you wouldn't want a shimmy in
flight. Is there any risk of that?
Andy
Old February 26th 09, 01:32 PM posted to rec.aviation.soaring
JJ Sinclair
Andy
Some will experience what is known as the "clunk". That is the sound
you may hear when rolling into a thermal. It is the fuselage sliding
in the lift fittings and going "clunk". If you hear this you need at
least a 20 thousands shim on one aft lift fitting, determine which one
by measuring from the TE probe on the fin with a steel tape to a
common point on each wing, say the aileron cut-out. Don't be surprised
to find your prize possession is off by close to an inch! This will
tell you where to epoxy the shim onto one of the aft lift fittings.
Some will find their lift fittings are too tight which makes getting
the wing onto the lift fittings a chore. Clean the fittings and scrub
them with magic-marker, then put it together again. Then remove the
wing and observe the magic-marked pins. The shinny spots show the
interference fit areas. My ship showed a problem on the front end of
the forward lift fitting and the back end of the aft lift fitting. It
took months of working these areas down with emery cloth every time I
flew to finally get the wing to slide on easily. Believe me you don't
remove much steel with sandpaper!
JJ
Old February 26th 09, 04:42 PM posted to rec.aviation.soaring
noel.wade
JJ -
My fault, I wasn't clear enough - I meant the _other_ "lift-pins". My
spar pins are exactly as you describe: Kept in a set of PVC tubes with
well-greased felt inside so that they "self lubricate" every time I
pull them out or put them back in the holders.
I was referring to the alignment pins on each side of the fuselage
that plug into the root rib sockets and ensure the wing is at its
proper angle of incidence relative to the fuselage. They're a lot
smaller and I don't think I want "variable incidence" wings as I fly
around... ;-)
Thanks,
--Noel
Old February 26th 09, 07:42 PM posted to rec.aviation.soaring
Andy[_1_]
On Feb 26, 6:32*am, JJ Sinclair wrote:
This will tell you where to epoxy the shim onto one of the aft lift fittings.
I don't doubt JJ knows this but the Schleicher approved method of
shimming the lift pins is to remove the lift pins and put the shims
behind them.
When I did this job on my 19 I found it best to do a trial fit by
putting the shims on the outside face of the lift pins. A little
grease will hold them in place. When the right additional shim
thickness is found the lift pins are driven out, the shim stack
adjusted, and the lift pins driven back in. I set mine up so there
was no detectable fore/aft motion at the wing tips but the main spar
pins could still be easily inserted.
Andy
Rust in tight places mhorowit Home Built 12 May 19th 09 09:40 PM
Rust prevention: Inside fuselage Michael Horowitz Home Built 10 August 20th 07 10:33 PM
Rust Baver 2 acroman Aviation Photos 0 August 19th 07 04:00 PM
Shaking off the Rust john smith Piloting 22 March 1st 07 12:36 AM
Rust inhibitor? Steve Thomas Home Built 10 August 30th 03 09:34 PM
